12-12-2015, 12:20 AM | #1 |
Newbie Join Date: Dec 2009 Location: ANDOVER TOWNSHIP
| Servo horn
New Wrangler CRC Unlimited with the Tactic TSX45 servo on it's way. How many teeth does the Tactic TSX45 have. Info for these Axials are pretty hard to come by. Want to purchase an aluminum horn. Thanks
12-12-2015, 12:36 AM | #2 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
| Re: Servo horn
25t (same as Futaba servos)
12-12-2015, 03:04 AM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Servo horn
25t Futaba spline, Ofna servo horn #10776 fits well if you can find one in stock. The Axial aluminum 25t horn #AXI30836 is well made too. This Protek is another one I know fits. ProTek RC Aluminum Long Clamp Servo Horn (Blue) (25T-Futaba/Savox) Robotronics, identical to the Protek. Robitronic Aluminum Servo Horn (Red) (25T-Futaba/Savox The Axial aluminum servo horn has linkage mount holes at 16mm and 20mm from the servo output shaft. All the other horns mentioned above are 19mm and 24mm from the servo output shaft. These will give you more throw from the servo compared to the stock plastic and upgrade Axial horns. |
Servo horn - Similar Threads | ||||
OFNA Servo Horn stout enough for Protek 170T Servo? | Banjoblue | Axial Wraith | 2 | 06-25-2015 05:30 PM |
metal gear servo, servo horn screws... M2, 4-40, M3??? | dieselfuel | General Crawlers | 7 | 12-25-2006 07:00 PM |
