12-15-2015, 03:13 AM | #1 |
Newbie Join Date: Dec 2009 Location: ANDOVER TOWNSHIP
| Ae 2 esc
Can I use a 7 cell 8.4 volt? I've heard people trying 3s 11.1 volts,but I don't want to cause any damage. Info on these Axials SUX!!! Was told to go to Axial.com/instructions on how to change Lipo mode but that info is NOT there. Only how to manually change things without a program card!?!?!??!
12-15-2015, 06:18 AM | #2 | |
| Re: Ae 2 esc Quote:
The short version: 1) Connect Castle Link to the AE2 as per the Castle Link instructions. 2) Set Cutoff Voltage to No Cutoff 3) Save Settings to the ESC. Last edited by k7zpj; 12-15-2015 at 06:22 AM. | |
12-15-2015, 06:36 AM | #3 |
Newbie Join Date: Nov 2015 Location: Freeport
| Re: Ae 2 esc
I run the Ae2 and can't remember how to manual switch without a card or usb kit but you can do it. Google is your friend. With that, it won't harm the esc regardless of voltage cutoff setting. If it's set on Lipo your battery run time will just be really short.
12-15-2015, 09:39 AM | #4 |
Newbie Join Date: Dec 2015 Location: Oconee County, SC
| Re: Ae 2 esc
You just have to look in the right place http://docs.axialracing.com/instruct...e_AE-2_ESC.pdf 6 Cell nihm (7.4v) or 2s Lipo is what the AE 2 is rated for. So no a 7 cell (8.4v) or 3s wouldn't be recommended. http://docs.axialracing.com/instruct..._and_Specs.pdf Last edited by Redbone; 12-15-2015 at 09:44 AM. |
12-15-2015, 10:23 AM | #5 |
RCC Addict Join Date: Dec 2005 Location: Tucson
| Re: Ae 2 esc
Been running 3s on my ae2 for about a year with no problems with castle b.e.c auto lipo 3.2 volts per cell cutoff |
12-15-2015, 10:42 AM | #6 |
Quarry Creeper Join Date: Dec 2014 Location: Surprise
| Re: Ae 2 esc |
12-15-2015, 02:52 PM | #7 |
| Re: Ae 2 esc |
12-15-2015, 05:15 PM | #8 |
| Re: Ae 2 esc |
Ae 2 esc - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
