12-21-2015, 10:51 PM | #1 |
Pebble Pounder Join Date: Mar 2010 Location: Eugene
| Wroncho help!!!
So I'm piecing together a wroncho, well trying. I have been monkeying with stuff to see what will work and what won't. I think I'm close but need some help with electronics. I have a forward mounted battery tray, but it hits the links now at full flex. I think I can make the tabs longer to get that to work. I also have a truggy chassis on order so I'm not sure what to do with the ESC and receiver. Any info? I will post pics of what I have so far. Also any other battery options with a chassis mounted servo?? |
12-22-2015, 03:01 AM | #2 |
Newbie Join Date: Dec 2015 Location: Oconee County, SC
| Re: Wroncho help!!!
One option is to move your battery out to the sliders have to mount two to balance the weight
12-22-2015, 11:19 AM | #3 |
| Re: Wroncho help!!!
I put my Rx box out back as a gas tank. You have to extend the servo wire.
12-22-2015, 03:49 PM | #4 |
Pebble Pounder Join Date: Aug 2011 Location: gaylord
| Re: Wroncho help!!!
What cms is that, and can you get some closer pics of the setup
12-22-2015, 04:43 PM | #5 |
| Re: Wroncho help!!!
Thank you guys. I've done some tinkering I'm close. It's the Vanquish SCX10 cms chassis mount with the Vanquish Wraith 3 link and panhard kit. It went together well. I did have to change the link ends and try different things to get the angles correct.
12-22-2015, 04:52 PM | #6 |
Pebble Pounder Join Date: Mar 2015 Location: PEI Canada
| Re: Wroncho help!!!
You could put the electronics in a fuel cell in the back, or on the rock slider.The battery could go on the rock sliders. Do you have any pictures of the battery mount?
12-22-2015, 07:35 PM | #7 |
| Re: Wroncho help!!!
I don't have any pics yet. I had to order some parts. I will post better pics of the CMS.
12-22-2015, 10:14 PM | #8 |
Rock Stacker Join Date: Sep 2005 Location: prescott
| Re: Wroncho help!!!
Like the link mount plates.Good job. |
12-22-2015, 10:16 PM | #9 |
| Re: Wroncho help!!!
Those are the TODBLDZ plates he's a vendor on here. Awesome product for Wroncho's!
12-22-2015, 10:54 PM | #10 |
| Re: Wroncho help!!!
Here's some other pics |
12-22-2015, 11:59 PM | #11 |
Rock Crawler Join Date: Apr 2009 Location: bend
| Re: Wroncho help!!!
When I was going to build a wroncho I looked at other peoples builds. I used a wraith center section Rear links wraith. Front uppers scx 10 Front lowers made from delrin. You can also check out Harley's design on you tube. He has a series on a wroncho he built. |
12-23-2015, 05:35 PM | #12 |
Pebble Pounder Join Date: Jun 2006 Location: newark
| Re: Wroncho help!!!
I have three wroncho's and the two that are use todd's plates I run two small 3s on the sliders
12-27-2015, 12:31 PM | #13 |
Quarry Creeper Join Date: Jun 2009 Location: South Crawl-o-lina
| Re: Wroncho help!!!
I always just use the factory battery tray and attach it on the front of the WronchoPlates. I have swapped to the HeliosRC 3000 mah 3s lipos which are very compact and lightweight so there no big change in my center of gravity. I mounted my electronics in the rear since I am running the servo winch in the front. #TheLab |
12-27-2015, 09:51 PM | #14 |
| Re: Wroncho help!!!
I like that. I may have to do that.
12-28-2015, 01:11 AM | #15 |
Newbie Join Date: Dec 2015 Location: london
| Re: Wroncho help!!!
I run two small 3s on the sliders |
12-28-2015, 11:19 AM | #16 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
| Re: Wroncho help!!!
Those Double D shock plates tho....
12-28-2015, 12:19 PM | #17 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
| Re: Wroncho help!!!
You could run the battery across the front rails in front of the motor. You can use the upper cross brace to bolt it to. I Run this on several trucks.
12-28-2015, 03:52 PM | #18 |
| Re: Wroncho help!!!
I decided to order the Jevne Racing CMS battery mount, and am happy I did! It's going to work perfect! I also will be using a Wraith electronics box next to the servo. |
12-28-2015, 04:56 PM | #19 |
| Re: Wroncho help!!! |
Wroncho help!!! - Similar Threads | ||||
Wroncho | k goodrich | Axial SCX-10 | 75 | 01-27-2018 12:30 AM |
My 2.2 wroncho | lastking | 2.2 Scale Rigs | 2 | 09-12-2014 01:38 PM |
Wroncho | Straxus | 2.2 Scale Rigs | 0 | 04-19-2014 07:48 PM |
