Thread: Slipper clutch tightness
Old 07-12-2016, 07:26 PM   #1
Default Slipper clutch tightness
How tight do you guys run your slipper clutch? I run all steel gears and I recently had to do a bearing change on my transmission and I noticed my slipper pad(s) seem stuck together. I been running mine pretty tight, if not all the way tight. Is this ok or should I run it looser?
big_poppa49 is offline   Reply With Quote
Old 07-12-2016, 07:29 PM   #2
Try backing it off a half turn
I would try just backing it off a bit first
seal20 is offline   Reply With Quote
Old 07-12-2016, 08:13 PM   #3
Default Re: Slipper clutch tightness
You think I need a new one since it's stuck together or what should I do?
Old 07-12-2016, 10:36 PM   #4
Tighten all the way down then back off 1/4 to 1/2 turn...
Personally I'd crank it down all the way and leave it...
tapped-out is offline   Reply With Quote
Old 07-13-2016, 01:01 AM   #5
I may just either leave it all the way tight or maybe half a turn backed out. If I get in a tight spot and I see its not going to go, I don't keep pushing. Especially being that I'm running all steel gears
Slipper clutch tightness - Similar Threads
Slipper clutch desertdude Axial Yeti 3 04-06-2015 02:30 PM
Slipper clutch. Do you need it? natskiboy Axial SCX-10 7 04-20-2012 05:12 PM
Slipper clutch ? Gso125 Losi Micro-Rock Crawler 3 02-08-2011 07:29 AM
slipper clutch help mesooners Team Losi Comp Crawler 6 07-10-2009 10:33 AM
