08-11-2016, 05:26 PM | #1 |
Pebble Pounder Join Date: Mar 2016 Location: Mountains
| transmission problems
I have the scx10 deadbolt. Been slowly upgrading as needed. I finally stripped the plastic gear in the transmission. So i order a set of steel hot racing gears from The Crawl Space. got them in stall a few days ago and ran it once, everythng worked good. tonight I went to screw around with it and spun the tires and the transmission sounded like it was making a clicking sound. So i tore in to the transmission and took it apart. Ran smooth! put it back together and it clicked and I could feel it catching. loosened up bolts around motor plate and it stopped. What in the heck is going on. what am i not seeing or missing? thank you in advance for your imput.
08-12-2016, 09:10 AM | #2 |
Pebble Pounder Join Date: Feb 2015 Location: in my house
| Re: transmission problems
Is your pinion/spur gear meshed correctly (ie the correct distance apart)? I'm thinking they might be too close together. If you can stick a piece of paper between the pinion and spur, then they are meshed correctly. Also I would check to make sure that there is clearance between the pinion/spur gears and the gear guard, and between the gear guard and the driveshaft
08-12-2016, 09:34 AM | #3 |
over tightening the bolts will cause the housing to flex...either locktite the bolts where they dont distort the case or upgrade to the aluminum case...
08-12-2016, 04:07 PM | #4 |
thank you. I will look into the gears are meshed. and the spacing and all.
08-13-2016, 08:56 AM | #5 |
[QUOTE=caleb.cole;5547989]Is your pinion/spur gear meshed correctly (ie the correct distance apart)? I'm thinking they might be too close together. If you can stick a piece of paper between the pinion and spur, then they are meshed correctly. Also I would check to make sure that there is clearance between the pinion/spur gears and the gear guard, and between the gear guard and the driveshaft[/QUOT Thank you. I took the trans apart to check the mash and spacing. Everything looked good. I recently put in new bearings, and thought maybe one was bad so I took out the bearings and cleaned everything back up and no more problems. |
08-13-2016, 09:00 AM | #6 |
| Re: transmission problems I didnt over tighten the bolts just till they were snug. but I did loc-tite the bolts. But I am thinkng I mght go with an aluminum like you suggest.
08-13-2016, 09:27 AM | #7 |
Using a pick or the tip of an exacto knife blade etc clean the debris out of the teeth on the spur gear.
08-13-2016, 12:53 PM | #8 |
| Re: transmission problems I did that as well, got a lot of gunk out smh. as well as ran a q-tip around the bearings and all and got more gunk. thought I cleaned it all better than that lol
08-13-2016, 03:51 PM | #9 |
| Re: transmission problems You should put some grease in as well to prevent more stuff from getting in. I use Lucas Oil Marine Grease and no water gets in.
08-14-2016, 09:49 AM | #10 |
| Re: transmission problems I use AGS LITH-EASE white lithium grease. its multi-purpose all weather grease. its good for farm equiment to marine use. love the stuff
transmission problems - Similar Threads | ||||
Transmission Problems | FilthyWraith | Axial Wraith | 4 | 03-09-2014 06:39 PM |
Transmission problems xr 10/ vanquish bushings | dusty sweep | Axial XR10 | 5 | 11-28-2010 10:49 AM |
mrc transmission problems | marshall381 | Losi Mini-Rock Crawler | 8 | 08-23-2010 10:43 AM |
R-2 Transmission problems | ToyotaKing88 | General Crawlers | 7 | 12-06-2007 10:23 AM |
RC4WD transmission problems | Coligny | Comments, Suggestions, and Help | 3 | 12-02-2007 03:16 PM |
