Thread: Can I get a quick Transmission suggestion?
Old 08-14-2016, 03:44 PM   #1
Default Can I get a quick Transmission suggestion?
Basically stock SCX 10. Made all my own Arms and such. I stripped the stock gears and put it on the shelf 2 years ago...
I'm ready to get a new Transmission... What do you guys suggest?
Novice user that doesn't play that much...
Thank you!
SicJK is offline   Reply With Quote
Old 08-14-2016, 03:59 PM   #2
Default Re: Can I get a quick Transmission suggestion?
Super Duty Light Weight Steel Gear Set - Super Shafty
No need to replace the whole transmission when it's just the center gear that stripped. That gear set will keep it from happening again, ever.
WHITE-TRASH is offline   Reply With Quote
Old 08-14-2016, 04:07 PM   #3
Thank you.
Old 08-14-2016, 04:12 PM   #4
No problem. If your trans has non pin style outputs I'd highly recommend getting the newer axial steel pin style. You'll thank me later when you don't have any more issues.
Old 08-14-2016, 04:28 PM   #5
I'm assuming you're referring to Part Number AX30435 ? Yes I have the PIN style Output Shafts. Please advise as to anything else that I mite replace while it's apart.
Old 08-14-2016, 04:34 PM   #6
You already have the good outputs. Just replace the gears and give them some grease and they'll be solid for years to come.
Old 08-14-2016, 04:38 PM   #7
I'm getting' ready to pull the trigger at Super Shafty
Old 08-15-2016, 03:53 PM   #8
Thank you WHITE-TRASH. I appreciate your help. Parts were ordered yesterday. Tossed in a set of bearings as well. ...and a new front Drag link.... Okay.. I stopped with just that, but damn I got carried away on their site...
Thanks again.
Old 08-26-2016, 11:09 AM   #9
Has anyone had issues with Super Shafty?
I placed an order on the 14th... (For stuff I could have purchased locally but took the suggestion of a good member here) and have not received it yet. I waited 5 days after I placed my order to even get an order confirmation. Then a Tracking number was issued after I contacted them via FB... Just want my parts, not flaming.....YET!
Can I get a quick Transmission suggestion? - Similar Threads
For Sales Section Change suggestion. Just a suggestion!! Oscar da Grouch Comments, Suggestions, and Help 25 12-21-2014 08:12 PM
I have one quick question about the transmission on my ridgecrest (RRP gears). axial 4x4 crawler Axial AX10 2nd-gen 4 12-17-2013 11:58 AM
Quick axle/transmission question mathcanbefun Losi Micro-Rock Crawler 6 09-12-2013 06:57 PM
California Gun owners. Quick question, need a quick answer. Szczerba Chit Chat 8 11-23-2010 12:35 AM
