08-24-2016, 01:26 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: ny
| I have a Noob question
What pinion would you recommend for the scx10 I have a brand new 35t rc4wd motor Has stock transmission gears Oh and what pitch Sorry if this makes me sound dumb Sent from my iPhone using Tapatalk |
08-24-2016, 09:57 PM | #2 |
Pebble Pounder Join Date: Feb 2014 Location: Southern Crawlorado
| Re: I have a Noob question
It would be helpful for us-the community, to know what spur you are running or if you plan on replacing both the spur gear and pinion gear. Additional information will help us help you.
08-24-2016, 10:51 PM | #3 |
I believe it to be a stock spur gear Sent from my iPhone using Tapatalk |
08-24-2016, 11:11 PM | #4 |
Rock Crawler Join Date: Mar 2016 Location: HB
Also what your trying to do with the rig. Faster pace trailing or more slow speed crawling. Lower tooth count on the pinion=slower, higher tooth count=faster. It's the opposite for the spur gear.
08-24-2016, 11:20 PM | #5 |
I'm just going for a fast walk Now on my r1 I'm going speed Sent from my iPhone using Tapatalk |
08-24-2016, 11:38 PM | #6 |
The stock setup on my CR edition rubicon is 20T pinion 87T spur with 48 pitch on a 27T motor. What scx do you have? Some have the 32P gears. My stock setup was great for both trailing and crawling until my lady smoked the motor and esc. Are you running 2S or 3S? Your going to need to know the pitch to buy the right pinion btw
08-25-2016, 04:04 AM | #7 |
I have 2 and 3s packs Sent from my iPhone using Tapatalk |
08-25-2016, 05:43 PM | #8 |
I believe I have an original honcho Sent from my iPhone using Tapatalk |
08-25-2016, 05:49 PM | #9 |
I just bought a 13t 48p Robinson Sent from my iPhone using Tapatalk |
I have a Noob question - Similar Threads | ||||
This is a noob question, for sure.... | MAXXMASHER | Team Losi Comp Crawler | 4 | 07-29-2015 03:23 AM |
Noob Question | MDcrawler99 | Newbie General | 1 | 09-28-2014 05:58 PM |
Tire foam question. WARNING!!! Noob question! | tokdl | Tires and Wheels | 6 | 05-07-2014 10:55 AM |
Noob Question.... | rockdwg | Axial Wraith | 6 | 08-16-2013 11:49 AM |
Noob Question :) | solly98 | Axial SCX-10 | 29 | 12-24-2012 07:30 PM |
