08-29-2016, 02:40 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| Loose C-hub fix?
besides buying a new axle or clamping c-hubs,what do you guys do when your c-hub screws wont keep the hub tight?
08-29-2016, 02:53 PM | #2 |
| Re: Loose C-hub fix?
beef tubes? are you talking about where the c-hubs screw to the axle assembly?
08-29-2016, 02:57 PM | #3 |
yes. i could do beeftubes but would like to fix it with out buying anything. iam all about the free mods.
08-29-2016, 03:03 PM | #4 |
well, really not much you can do to fix stripped holes at that point....even if you buy a new axle housing, its gonna happen again...guaranteed... unless you want to epoxy the chubs on, but then if they break you are screwed anyway....
08-29-2016, 03:20 PM | #5 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
If all stock plastic maybe got up slightly on the screw diameter?
08-29-2016, 04:00 PM | #6 |
| Loose C-hub fix?
Get some jbweld fill in the holes leave a greased screw in let cure for 24 hours.hope it works Buy beef tubes or make your own, install longer screw HANG UP AND DRIVE ! Last edited by mikemcE; 08-29-2016 at 04:04 PM. |
08-29-2016, 04:32 PM | #7 |
CA glue. Tire glue. Super glue. Whatever. Put a blob in the hole.
08-29-2016, 05:57 PM | #8 |
i did the ca glue but it didnt hold for long.i have heavy ssd steel wheel on it and im sure that isnt helping. boom racing c-hubs. its almost like the inner diameter of the c hubs could be a tad bit smaller. im sure its a possibility with cheaper parts.
08-31-2016, 08:24 PM | #9 |
Newbie Join Date: Oct 2014 Location: Mobile
Just find a fatter screw, should take care of it. Sent from my iPhone using Tapatalk |
08-31-2016, 08:47 PM | #10 |
Drill/tap more screws around the C-Hub. Also, E-6000 glue dries flexible but holds. I've used that before with good luck. Will peel off if you need to remove c-hub. Found at most retail stores.
09-01-2016, 02:04 PM | #11 |
| Re: Loose C-hub fix? |
09-01-2016, 02:05 PM | #12 |
Loose C-hub fix? - Similar Threads | ||||
c-hub getting loose | wmax99 | Axial Wraith | 9 | 07-14-2013 04:32 PM |
Knuckle / c hub screws (kingpin?) coming loose | Matthewboerner | Axial Wraith | 9 | 10-14-2011 11:12 AM |
Wheel hub fix | Kanine38 | Newbie General | 3 | 05-11-2010 08:02 PM |
BERG/Stripped out C-Hub Fix | SaxtonSlaughter | Tools, and Procedures | 6 | 11-12-2009 09:54 AM |
BM16 with loose magnets - how to fix? | Nova's Ark | Electronics | 18 | 09-18-2008 10:42 AM |
