10-10-2016, 06:02 PM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| Need help with this issue (video)
It's stock esc and radio on my son's axial rtr wrangler g6. It's done this before bit quit on its own last time out, but now it's doing it again. I have full response on steering, but forward and reverse is acting weird. Apply full throttle and it keeps going on its own for a while then finally stops. Reverse is barely working. Battery is full charge. What can I do/try or is my esc toast? If you hold full throttle it will keep going and go fine, but release the throttle (suppose to suddenly stop) and it is almost like your still barely holding down the throttle. Also the THR trim is at neutral. https://youtu.be/f-9XTueHPsk. |
10-10-2016, 06:08 PM | #2 |
| Re: Need help with this issue (video)
adjust the throttle trim until it stops creeping, the trim doesnt always stay right at the neutral position...
10-10-2016, 06:17 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
try to calibrate the esc
10-10-2016, 06:21 PM | #4 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
low batteries in remote?
10-10-2016, 06:26 PM | #5 |
-tried adjusting trim, still does it -how do I calibrate the esc? -possible low tx batteries, will try that |
10-10-2016, 07:21 PM | #6 |
Ok just put new batteries in remote, still does it. Discovered something interesting, when I turn the throttle trim dial (as if I was driving it with the dial) it does perfectly fine, but when I go to use the trigger it does not act right |
10-10-2016, 09:40 PM | #7 |
| Re: Need help with this issue (video) |
10-10-2016, 10:45 PM | #8 |
Need help with this issue (video) - Similar Threads | ||||
MMP issue... i think i'm the issue. | concretejungle | Electronics | 12 | 08-13-2012 02:52 PM |
Steering Issue (With Video) | Hawthorne46 | Axial Wraith | 13 | 07-07-2012 11:54 AM |
need some help diagnosing this electrical issue - VIDEO | iamsuperbleeder | Electronics | 15 | 09-17-2011 10:08 AM |
