12-21-2016, 05:41 AM | #1 |
Rock Stacker Join Date: Aug 2016 Location: Maine
| ESC/Motor combo for crawling
So I already have a EzRun WP SC8 ESC laying around not being used and figured id use that in my new build for crawling. Any recommendation for a brushless motor that would match?
12-21-2016, 06:31 AM | #2 |
| Re: ESC/Motor combo for crawling
That ESC won't be ideal for crawling because it's not sensored.
12-21-2016, 06:44 AM | #3 |
| Re: ESC/Motor combo for crawling |
12-21-2016, 07:56 AM | #4 |
12-23-2016, 03:25 PM | #5 |
How about these? https://hobbyking.com/en_us/hobbykin...1-10-1-12.html Drag break? https://hobbyking.com/en_us/hobbykin...1-10-1-12.html |
12-23-2016, 03:31 PM | #6 | |
| Re: ESC/Motor combo for crawling Quote:
according to the manual, it only has 30% drag brake max....not a lot for a crawler.. | |
12-23-2016, 04:32 PM | #7 |
12-23-2016, 04:36 PM | #8 |
something that is more adjustable, 10-213%.... like the castle mmp... some wont use that much but its nice to have the option...myself, I never go below 50%
12-23-2016, 06:20 PM | #9 |
12-23-2016, 06:24 PM | #10 |
both of your links took me to the same esc...
12-23-2016, 08:10 PM | #11 |
Both of your links are to the same ESC. Do you need brushless for your crawler? If not you get can a good, brushed setup for under $100. |
12-24-2016, 05:02 AM | #12 |
| Re: ESC/Motor combo for crawling https://hobbyking.com/en_us/turnigy-...or-1870kv.html sorry meant to post this instead of the ESC twice |
12-24-2016, 05:04 AM | #13 |
| Re: ESC/Motor combo for crawling what combo is that. Im on the fence with brushless/sensored vs brushed. Not sure if it matters but all I have for batteries are 3s
12-24-2016, 08:55 AM | #14 | |
Holmes Hobbies Crawlmaster motor: CrawlMaster Expert 540 - CrawlMaster Series - Brushed Motors - Motors 3S batteries are good. You'll never run out of power and you can adjust your gearing for your desired speed and still have torque. | |
12-24-2016, 09:01 AM | #15 | |
One thing, why the crawl master 13t, I was looking at the torquemaster expect 30t for wheel speed? | |
12-24-2016, 09:12 AM | #16 | |
I also have ran the 27t, 30t, and 35t torque master motors and they are very good as well. any of them will be a good choice, for me...the 13t crawl master is my go to for dedicated crawling and light trailing, the 30t torque master is my go to for moderate trailing and light crawling and the roc 412 3100kv is for everything but running in water lol and I run everything on 3s | |
12-24-2016, 09:14 AM | #17 | ||
12-24-2016, 09:17 AM | #18 | |
that motor is only a 2 pole, while its not bad, you can get a 4 pole brushless that would have better low end resolution..but they will be more expensive. Team Brood has a new line of brushless motors out, one of them is a 4 pole for 99.00...looks pretty good for the price... | |
12-24-2016, 09:24 AM | #19 |
ESC/Motor combo for crawling - Similar Threads | ||||
Choice for ESC or ESC motor combo | fivepointnine98 | Newbie General | 10 | 07-05-2011 03:21 PM |
