12-27-2016, 10:45 AM | #1 |
Pebble Pounder Join Date: Apr 2014 Location: South Jersey
| Deadbolt transmission spur and pinion
I bought my daughter a rolling deadbolt chassis for Christmas and while I was installing motor/electronics I noticed that the spur gear is a course tooth and not fine like my son's dingo or my original scx10 truck? So now she has a running vehicle with no pinion yet and I wanted to get the pinion today at my lhs. Problem is he doesn't have deadbolt part's just "normal" scx10 fine tooth part's, can I just buy a fine tooth spur and pinion from a dingo or honcho and install it? To me everything seems identical except this new course spur gear? Axial didn't change the internal transmission part's also did they?
12-27-2016, 10:56 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Deadbolt transmission spur and pinion
All you need is a 32p 11 tooth pinnion 149 r/c worx |
12-27-2016, 11:07 AM | #3 |
It's 32p? If my memory is right I think all my tamiya vehicles use 32p also. I'll see what I have extra in the tamiya part's bin.and 11tooth that seems geared for rock crawling to me? On the other two scc10 I run stock spurs with 20t pinion, we trail and mud run so no rocks
12-27-2016, 03:09 PM | #4 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
THE 32p spur is 56t instead of the 80t 48p of the dingo
12-27-2016, 08:09 PM | #5 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Deadbolt transmission spur and pinion |
01-01-2017, 02:41 PM | #6 |
Me my daughter and son all went out today with our scx10's, they both have 45turn motors and it seems the deadbolt has little less torque and wheel speed compared to my son's with the stock 48pitch spur and 20tooth pinion. I'm gonna order the 48 pitch stuff and swap hers over
01-01-2017, 07:27 PM | #7 | |
| Re: Deadbolt transmission spur and pinion Quote:
In the long run with a 27 turn to 45 turn, the 5.09 ratio will help them last longer and run cooler...and have better low end resolution for better crawling.. you dont specify what battery you are running, Nimh, 2s lipo, 3s lipo, etc... you can gain the wheel speed back by upping the battery to a 3s lipo providing the ESC will handle it...volt up and gear down will make for a longer life on motors Last edited by allanon1965; 01-01-2017 at 07:30 PM. | |
01-02-2017, 08:57 AM | #8 | |
Deadbolt transmission spur and pinion - Similar Threads | ||||
32p spur gear for scx10 deadbolt | snapon boy | Newbie General | 23 | 01-09-2015 11:11 PM |
Pinion and spur | chevy9534 | Axial Wraith | 3 | 01-05-2012 07:48 PM |
spur/pinion??? | armycrawler101st | Newbie General | 3 | 11-06-2010 05:22 PM |
spur and pinion | diamondbackrc | Traxxas Crawlers | 0 | 07-14-2010 07:18 AM |
