Thread: Wheel offset
Old 01-07-2017, 08:32 PM   #1
Default Wheel offset
Hi, new to this forum and would like to seek some advice. I have a SCX10 Rubicon, and am planning to do upgrade. I will pick 1.9 Pit bulls Rock Beast and Crawler Innovation Foam. I notice most people are using wheel with -10mm offset for Rock Beast. Is such offset a must for wide tire like Rock Beast? My priority is to keep the scale look, and just afraid -5~0mm offset wheel does not work with Rock Beast. My current selection is a Gmade wheel with 0 offset.
iPhoneTapatalk
Supernova is offline   Reply With Quote
Old 01-08-2017, 12:01 AM   #2
Default Re: Wheel offset
I have a deadbolt and i used gear head wheels. They have two different off sets you can use. I went wide on the front about 9.75 inches wide on the front and 9.25 for the rear.
k goodrich is online now   Reply With Quote
Old 01-08-2017, 06:00 AM   #3
I have a scx10 and I have rc4wd hazard rims with rock beast xl tires and I believe the rims have a 0.65 offset and they work great and look amazing
Sent from my SM-G920R4 using Tapatalk
fhgbobcat is offline   Reply With Quote
Old 01-08-2017, 06:09 AM   #4
Thx for all your input. Seems having offset then make wider does not affect much to its look. Will final a new rim with negative offset
iPhoneTapatalk
Old 01-16-2017, 02:46 AM   #5
Just checked RCMart and have found Vanquish Method wheel. It mentions 'multiple offsets to adjust track width'. Would anyone advise if it needs option part to make it work?
Wheel offset - Similar Threads
Wheel offset? heinz357 Tires and Wheels 0 05-25-2013 12:30 PM
VP wheel offset longviewskyline Axial XR10 4 12-24-2010 03:15 AM
Wheel Offset yel98vwgti Tamiya CR-01 2 04-09-2009 12:19 AM
2.2 wheel offset fullmodtxt Newbie General 1 05-24-2006 08:06 AM
