01-15-2017, 09:24 PM | #1 |
Rock Crawler Join Date: Nov 2009 Location: bolivar mo
| Mighty' scx10
This is gonna be a continuous thread of this sick ass rig I bought a month or so ago. She was already built. If y'all remember me I've built over 25 rigs. Buying them is not my style but limited shop area and me being to busy with my TV show just don't have time. I'll add specs below. *VP Method 101 wheels 1.9 - black / black - No stripped holes or broken screws! *VP SLW hubs - black (.475 front and .350 rear) *1.9 Pitbull Rock Beast (non XL's) - vented using a leather punch tool *Crawler Innovations Deuce's Wild foams. *VP Currie Rock Jock - clear anodized front axle *VP Currie 3-link / panhard mount - clear anodized *VP 8 degree knuckles and C-hubs - grey *VP VVD front axle shafts *VP clamping locker - front axle *Axial HD bevel ring and pinion gears - stock ratio *VP wheel hexes - black *VP titanium tie rod, drag link, and panhard link *VP frame mount CMS - black *VP titanium suspension links front (3-link) and rear *VP Currie Rock Jock - clear anodized rear axle *VP clamping locker in the rear axle *Axial HD bevel ring and pinion gears (stock ratio) *Axial stock SCX10 rear axle shafts *VP wheel hexes - black *MIP drive shafts - front and rear *Pro Line Scaler shocks - front and rear *VP aluminum shock hoops - black - front and rear *Jeepin Doug aluinum shock stand-offs - front and rear (rare items!) *VP SCX10 Transmission housing - clear anodized *SuperShafty Beefy motor plate *Robinson Racing hardened steel idler and bottom diff gears in transmission. It has the stock metal top gear (input gear), and the Axial stock metal outputs on the bottom RR diff gear. *LockedUp RC slipper eliminator kit *BGR Fabrications JK front and rear bumpers - anodized black by Lattice Inovations. *BGR Fabrications JK rock sliders - anodized black by Lattice Inovations. *VP slider mounts - black The ESC, and BEC are mounted in the black plastic box, on the rear of the chassis. The HeyOk lighting controller is mounted in the Traxxas RX box, on the slider mounts. There's even a Tekin Hotwire plug ran out of the box, so I can make adjustments to the ESC without opening the plastic box. *Tekin RS Gen 2 esc *Tekin Gen 1 13.5 brushless motor *Hitech 7954 steering servo (with aluminum servo horn) *Castle Creations 10amp BEC *VP Rigid 6" light bar - black *HeyOk light controller *Modified Jevne Racing battery plate in the front, for the 3s lipo. *Krawler Koncepts rear tail light housings, door handles, and gas cap clear LED's in the front head light feature, and amber LED's in the parking light feature, on the body. There are also red LED's in the rear tail light housings. I bought it without a top and spare. I also added extinguisher and kMS winch. Sent from my iPad using Tapatalk Last edited by Mighty1; 01-15-2017 at 09:36 PM. |
01-16-2017, 01:01 PM | #2 |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
| Re: Mighty' scx10
Man where'd you get the soft top? That's rad!
01-17-2017, 01:16 AM | #3 |
Quarry Creeper Join Date: Sep 2010 Location: appleton
| Re: Mighty' scx10
Check out WICCRA on Facebook. He makes soft tops and tire covers. He will also custom build anything you want. https://www.facebook.com/groups/1169500779746659/ Sent from my LG-H900 using Tapatalk |
01-18-2017, 08:39 AM | #4 |
| Re: Mighty' scx10 |
Mighty' scx10 - Similar Threads | ||||
Mighty FC | Tossedman | 1.9 Scale Rigs | 9 | 11-17-2016 09:57 PM |
Mighty Tonka | mmatthews | 1.9 Scale Rigs | 22 | 01-06-2016 01:11 PM |
Mighty FC | 20 SMOKE | Paint and Body | 1 | 01-03-2016 08:35 AM |
Tonka Mighty Roughneck F150 SCX10 build | Jeff@TireBalls | Axial SCX-10 | 39 | 11-27-2015 08:07 PM |
Mighty FC | xxgg | Scale Videos! | 3 | 05-19-2012 11:59 PM |
