01-29-2017, 08:49 PM | #1 |
| 87T Steel Spur
What options do we have for 87 tooth steel spur gears for the SCX10? Thanks. |
01-29-2017, 09:25 PM | #2 |
| Re: 87T Steel Spur |
01-29-2017, 09:58 PM | #3 |
01-29-2017, 10:05 PM | #4 |
| Re: 87T Steel Spur
assuming 48 pitch ? Hot Racing... GPM - ebay... (there are other listings incl. helical cut teeth) ...likely others available as well ------------------------- or you could switch to running 32 pitch instead Pro: fewer teeth, stronger indivd. teeth, deeper mesh engagement, easier to set mesh, less prone to stripping/breaking. Con: tends to be louder, can cut thru electrical wires easier if left exposed. ------------------------ Steel is stronger and wears longer then aluminum spurs. The additional weight is negligible and more advantageous for a slow mo crawler that uses torque. For higher speeds... aluminum or delrin offer an advantage in rpm. |
01-29-2017, 10:18 PM | #5 | |
| Re: 87T Steel Spur Quote:
I don't run 48p anything, anymore. The only tell, that my rigs are even moving, is watching them move or the noise from a uni or MIP, that hasn't been lubed. I'm mainly a crawler. Not a scaler.. but I have a rig for every class(7 classes) in our hobby. Plus my son's few and my daughter's mini. My scalers all run brushless HH and 4s.. my scx is an animal, at 26mph or dead slow/Max torque crawling. My C3 Sexo, is easily a 30mph monster and snaps a speed on, in a heart beat. When strength is your end game.. it's everything else, in the drive line. The 32p spur is a cheap and easy replacement. But in my experience, still stronger then the HD axle gears. I have had more of them strip then a bad spur gear. Brushed 3s and brushless 4s.. Just my experience.. | |
01-29-2017, 10:51 PM | #6 | |
But why would you quote me and denounce mine ? You act as if yours is the only opinion. Yer entitled to disagree with my opinion. But my experience is mine... and no matter what your opinion... it doesn't change my experience. That said... I still run a plastic spur... because it's an inexpensive link... if something has to fail. Beefing up one component... generally just shifts the weak point to somewhere else. Beside throwing in your $ .02 worth of opinion and denouncing mine... Why didn't you answer the OP's inquiry ? He wanted to know what mfgr's offer a 48P 87T steel spur gear. Seems a simple enough inquiry to me. | |
01-29-2017, 11:11 PM | #7 | |
It was just the one thing, that I mentioned, about it being louder. And I use tapacrap, and I don't always get notifications, unless I'm quoted. And again, like you stated and I stated.. a plastic spur is the way to go. Because of why you posted. I think our experience's are both saying the same thing. As for manufacturer's. There are a few that do steel spurs.. costly and heavy, other then the HR. Like Robinson and supershafty.. Loud and noisy.. It's not always about, just answering the OP.. Knowing background and ideas, normally leads to a better end result, for the OP and future/other readers. | |
01-29-2017, 11:25 PM | #8 | |||
just wanted to know some facts !? just sayin' ...no hard feelings Last edited by TacoCrawler; 01-29-2017 at 11:30 PM. | |||
01-29-2017, 11:51 PM | #9 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Re: 87T Steel Spur
If the OP doesn't want opinions of any kind, he could also use the search function at Google.com to find what he's looking for. Sent from my SM-G930F using Tapatalk |
01-30-2017, 12:43 AM | #10 |
| Re: 87T Steel Spur
so hospitable you are Why can't people read the context of a thread... "What options do we have for 87 tooth steel spur gears for the SCX10? Thanks." and see that the OP has nearly 3,200 posts so they must have some sort of clue. And accept it for what it is ? a direct inquiry to what's available. btw... he asked for options... not opinions what makes that offensive ? Sometimes, would seem, it's unfriendly to ask a simple direct question... and hope for a simple answer. ~ geessh ~ there is a chit chat folder for those idle conversations/arguments of nothingness |
01-30-2017, 01:19 AM | #11 | |
That being said, I know of a steel spur.. This one.. I bought this set for one of my rigs. Works perfectly so far : http://www.jazrider.com/axial-racing...-90060194.html Is it the same as the GPM, maybe? Last edited by tjohanne; 01-30-2017 at 01:26 AM. | |
01-30-2017, 04:29 AM | #12 | |
And so should you(with 2600)! But we all know, posts don't equal knowledge... This isn't FB!!! Want a simple answer and someone to do it for you, go there. Hopefully, this goes in chit chat or the newbie section.. better yet.. erased! It's a worthless thread.. Good day, sir | |
01-30-2017, 06:02 AM | #13 | |
I did search for 87T, 48P steel spur gears. I only found this HR gear and a Robinson Racing version. The RR was too expensive IMO. The issue with the HR gear is that it has an oddly shaped recess for the slipper pad. And I couldn't find a pad with that shape. Do you know if the Axial pad will fit this gear? | |
01-30-2017, 06:26 AM | #14 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: 87T Steel Spur https://www.amazon.com/ECX-Slipper-A...YVNF6PAGA074QN I don't think the axial pads will fit unless you cut them. I see hr only lists aluminum 86-88-89t spurs for 48p axial. Last edited by 351Beno; 01-30-2017 at 06:36 AM. |
01-30-2017, 07:31 AM | #15 | |
01-30-2017, 07:49 AM | #16 | ||
I searched Google and I looked before posting. I asked a simple question. If you couldn't answer that then why bother posting? You posting useless responses is more clutter on this site than my simple questions and simple responses. Quote:
Like you said, post count doesn't equal knowledge. I've only been in RC for about 30 years and a mechanical engineer for 10 years. This thread was not useless until you chimed in. Last edited by JatoTheRipper; 01-30-2017 at 08:30 AM. | ||
01-30-2017, 09:04 AM | #17 | |
And as I mentioned, there is also that Jazrider metal spur gear.. | |
01-30-2017, 09:11 AM | #18 | |
Quarry Creeper Join Date: Nov 2013 Location: alberta
01-30-2017, 09:17 AM | #19 | ||
Nobody said his response was an offense. I read his response and kindly expressed my preference to stick to 48P gears. How is that offensive? It's more offensive, IMO, to completely disregard the OP of a thread. I've tried 32P gears and use them where I feel that they're necessary. They're not necessary on an SCX10 IMO. Despite your comment, I did do research before posting this question. I found the HR and RR 87T steel spurs and that was it. Is it so bad that I was asking this question to see if I had missed any since I could not find one specifically for the SCX10 with the hex slipper pad? I already have extra slipper pads so it would be great if I found an 87T steel spur that could use these pads. Quote:
01-30-2017, 09:30 AM | #20 | |
Sent from my SM-G930F using Tapatalk | |
87T Steel Spur - Similar Threads | ||||
anything smaller than an 87t spur for AX10 trans? | crazyorigin | Axial AX-10 Scorpion | 2 | 10-14-2010 05:13 PM |
Does anyone make a Alum/Steel 87T spur? | ADDICT | Axial AX-10 Scorpion | 2 | 09-18-2008 07:50 AM |
steel spur | Maxx4life | General Crawlers | 1 | 08-23-2005 11:25 PM |
