Thread: What size MIP shafts for 2 speed transmission
Old 12-16-2017, 02:30 PM   #1
Default What size MIP shafts for 2 speed transmission
Hello, I have a 12.3 inch wheelbase SCX10 with an SSD two speed transmission installed. The transmission is flipped around from the stock configuration (the spur gear now faces forward), so the front driveshafts are stock length, and the rear driveshafts are shorter, as the transmission only sticks out on the rear side. I am looking to upgrade said driveshafts to MIP ones, but I do not know which ones will fit. I know there is a kit for the ax10 with a dig transmission, linked below, but I have no idea if it will fit. Also, are there any specific parts I need to get it to fit, or is there one that is slightly too large that I can cut to make it fit? Thank you.
https://www.amainhobbies.com/mip-cdr...content=Brands
The length for the rear one (collapsed and end-to-end) is 96mm and the length for the front (collapsed and end-to-end) is 106mm
caleb.cole is offline   Reply With Quote
Old 12-17-2017, 11:40 AM   #2
Default Re: What size MIP shafts for 2 speed transmission
Not sure but worth noting there support advised me that I needed a minimum of 3/8" left in the female half.... There's quite a lot of spline to play with to achieve that
Sent from my Pixel using Tapatalk
Crawler Cads is offline   Reply With Quote
Old 12-18-2017, 06:54 AM   #3
I did some research, and measured my driveshafts more, and figured out that mip09136 should work. I ordered it and hopefully it will fit.
What size MIP shafts for 2 speed transmission - Similar Threads
SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) bizarrefish Axial SCX-10 8 08-09-2016 09:36 PM
