12-16-2017, 02:30 PM | #1 |
Pebble Pounder Join Date: Feb 2015 Location: in my house
| What size MIP shafts for 2 speed transmission
Hello, I have a 12.3 inch wheelbase SCX10 with an SSD two speed transmission installed. The transmission is flipped around from the stock configuration (the spur gear now faces forward), so the front driveshafts are stock length, and the rear driveshafts are shorter, as the transmission only sticks out on the rear side. I am looking to upgrade said driveshafts to MIP ones, but I do not know which ones will fit. I know there is a kit for the ax10 with a dig transmission, linked below, but I have no idea if it will fit. Also, are there any specific parts I need to get it to fit, or is there one that is slightly too large that I can cut to make it fit? Thank you. https://www.amainhobbies.com/mip-cdr...content=Brands The length for the rear one (collapsed and end-to-end) is 96mm and the length for the front (collapsed and end-to-end) is 106mm Last edited by caleb.cole; 12-16-2017 at 02:48 PM. |
12-17-2017, 11:40 AM | #2 | |
Quarry Creeper Join Date: May 2017 Location: Devon
| Re: What size MIP shafts for 2 speed transmission Quote:
Sent from my Pixel using Tapatalk | |
12-18-2017, 06:54 AM | #3 |
I did some research, and measured my driveshafts more, and figured out that mip09136 should work. I ordered it and hopefully it will fit.
What size MIP shafts for 2 speed transmission - Similar Threads | ||||
SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) | bizarrefish | Axial SCX-10 | 8 | 08-09-2016 09:36 PM |
