07-27-2018, 12:49 PM | #1 |
Newbie Join Date: Feb 2018 Location: Phoenix
| What initial upgrades
OK so I am having surgery and will be out of work for 2 months. I have convinced my wife that I need upgrades to my scx10, to keep from going crazy. So my question is what initial upgrades would you all suggest? Sent from my SM-G965U using Tapatalk |
07-27-2018, 01:40 PM | #2 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
| Re: What initial upgrades
Good luck with the surgery! Do you have a RTR or a kit? Sent from my iPhone using Tapatalk Pro |
07-27-2018, 01:51 PM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
High torque steering servo,aluminum,stainless steel or titanium suspension links with beefy metal ball rod ends.Pick your budget with the links.Metal steering links as well.As for electronics I would choose a 35t brushed motor setup with a hobbywing 1080 esc.Tires will vary with your terrain you run on.Lots of opinions on shocks too.Thats another category of how much you want to spend.Lightweight lexan truck body of your choosing also. That's not a lot of money to dramatically improve the performance of the scx10 Keep us posted on your progress. |
07-27-2018, 05:16 PM | #4 |
Its second hand so don't know if it was a kit or rtr ... I know I'll have to upgrade links since it uses the wishbone. I also know it has a 12" wheelbase Sent from my SM-G965U using Tapatalk |
07-29-2018, 08:01 PM | #5 |
Rock Stacker Join Date: Jan 2016 Location: NorthBay, Ca
When I upgraded my SCX10 I installed a forward battery mount. The battery sits lower and forward of the stock position. It sits just behind the front wheels. This modification helps the handling in a big way. I'd think about some better tires too. There are a lot of options out there! |
07-30-2018, 07:33 AM | #6 |
Newbie Join Date: Jun 2018 Location: milwaukee
my first change was the ESC. I installed a castle sidewinder 3 ESC to enable much slower crawling speeds. it is easy to program the throttle response to your liking. Second was a BEC, to low more power to the servo. I installed the Castle 10A blue BEC. then, tires, I put the Hydrax tires on, I think that they grip much better than the stock tires. ...the list can go on and on,.... |
08-05-2018, 02:31 PM | #7 |
Pebble Pounder Join Date: May 2013 Location: lemont
Good steering servo, grind the drive axle cups mod.. metal c hubs and knuckles-(i seem to break the plastic knuckles alot at the steering part)
What initial upgrades - Similar Threads | ||||
Axial SCX10 Deadbolt Initial Upgrades? | DanRC | Newbie General | 9 | 12-27-2015 08:27 PM |
Question on motors and genereal initial upgrades | sleepy floyd | Newbie General | 31 | 12-01-2015 07:20 AM |
Initial observations | JasonInAugusta | Vaterra Twin Hammers | 21 | 02-19-2013 08:56 PM |
Initial Charge?? | xjnation | Electronics | 10 | 11-03-2005 10:43 AM |
Initial LATHE purchase | BlueMonster | Tools, and Procedures | 4 | 05-12-2005 08:19 PM |
