06-05-2016, 02:50 PM | #1 |
Pebble Pounder Join Date: Dec 2014 Location: Tip of the Mit
| TF2 Mojave fitment?
So who's going to be the first to do it? Curious as to what will need to be done to make it work as that's my plan once The dust settles and I can buy one from tower.
06-05-2016, 04:59 PM | #2 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: TF2 Mojave fitment?
All things are possible with a little bit (or a lot) of work. Start by shortening the rear links to get the WB correct: If you use the full cab back, you'll need to trim to clear the tranny: The half cab back should work fine without modification. A large stick pack may get in the way of the dash depending on what dash you use (CC Hand pictured): You wouldn't be able to do a full-depth interior without major rearrangement of mechanicals, but you should be able to fit the stock dash and most of a bench seat without too much effort. |
06-06-2016, 03:54 PM | #3 |
Wow, thank you sir! Shouldn't be bad at all. |
TF2 Mojave fitment? - Similar Threads | ||||
2003EDGE's TF2 Mojave II Buildup | 2003EDGE | RC4WD Trail Finder 2 | 20 | 01-01-2016 01:57 PM |
