09-05-2016, 01:51 PM | #1 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Diff gear death
I know two of the guys that I run with that are having issues with the gears. Is anyone having issues with this if so how did you fix it? I have a new kit and have not assembled it yet. I don't know if it's already been talked about and maybe I just can't find it
09-05-2016, 02:07 PM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: The Netherlands
| Re: Diff gear death
there's a difference between 'diff gear death' and 'guys having issues with the gears'. What issues are they having, how were they running it (huge motor on 6s or 27t on 2s)? Can't say much otherwise. I've not read about anyone having issues with the gears in the diffs so far, and have no problems myself. |
09-05-2016, 02:14 PM | #3 |
| Re: Diff gear death
Slipping teeth inside the differential. Which is inherently bad for any ring and pinion gear setup Sent from my SM-G900P using Tapatalk |
09-05-2016, 06:11 PM | #4 |
| Re: Diff gear death
I think it was one of the Holmes videos talking about people have cracked and split the spools. A broken spool that allows the driveshaft tangs to rotate would feel a lot like a slipping gear.
09-05-2016, 06:23 PM | #5 |
| Re: Diff gear death
From what I understand one guys install a shim in his and it stopped clicking. As for the other guy he's just started Sunday and it wasn't very loud either
09-05-2016, 08:35 PM | #6 |
Newbie Join Date: Oct 2010 Location: Your moms house...
| Re: Diff gear death
They will click and bind when the drive shaft is not installed. The shaft has very little tolerance against the pinion bearing so it pulls the pinion out and prevents misalignment of the gear teeth. Without the drive shaft installed the diffs will click when turned by hand.
09-05-2016, 08:43 PM | #7 | |
| Re: Diff gear death Quote:
This was while driving with all shafts installed 30 degree slope. I have already built a few of these trucks. I just haven't built mine. The last one I built Last edited by greengoblin; 09-05-2016 at 08:47 PM. | |
09-06-2016, 08:46 PM | #8 |
Newbie Join Date: Nov 2014 Location: Marietta
| Re: Diff gear death
I will be following this as I have one that I acquired due to damaged diff gears. It was a 3s/Pro4 setup though.....
09-06-2016, 09:16 PM | #9 |
| Re: Diff gear death
Im building my set for my scx10 II now. I got the beef tube bt007b axle housings. Stock housing Beef tube housing |
09-07-2016, 05:47 AM | #10 |
Rock Stacker Join Date: Aug 2016 Location: In the doghouse
| Re: Diff gear death |
09-07-2016, 06:02 AM | #11 |
09-10-2016, 05:37 AM | #12 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
09-10-2016, 07:26 AM | #13 | |
Always stand my Sharpie with the felt end down about 10 or 15 minutes before I use it | |
09-14-2016, 01:59 PM | #14 |
Pebble Pounder Join Date: Mar 2016 Location: Pacifica
| Re: Diff gear death
This is from "bilinvic" build thread; Re: bilinvic's SCX10 II One important note...make sure you shim the pinion output shafts between the exterior diff housing bearing and the driveshaft...the mesh can really get rough if the pinion is allowed to slide in a bit. bilinvic's SCX10 II I hope it helps. ~D Last edited by Say what?; 09-14-2016 at 05:46 PM. |
09-15-2016, 08:18 AM | #15 | |
09-22-2016, 07:14 PM | #16 |
| Re: Diff gear death
Well i just added the shim to mine. The other truck i built has come home for a while. I'm going to tear into it and see if there's any deer damage and then shim it also.
Diff gear death - Similar Threads | ||||
diff gear help please | jboogieroc | Axial Yeti | 7 | 03-02-2016 01:14 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
Diameter of the diff gear | Mnster | Losi Mini-Rock Crawler | 0 | 12-20-2008 12:39 AM |
diff gear | Slipknot23 | Kyosho Crawlers | 6 | 07-26-2005 11:57 PM |
