02-07-2017, 07:46 PM | #1 |
Quarry Creeper Join Date: Mar 2016
| Shorter rear links
Is anyone selling on the market yet shorter rear links to convert the scx10-2 from 313 to 290 so I can mount my Mighty FC body. Sent from my iPhone using Tapatalk |
02-07-2017, 09:10 PM | #2 |
Rock Stacker Join Date: Sep 2015 Location: East Highland
| Re: Shorter rear links
Hit up nerby149, he will make you anything you want.
02-08-2017, 07:09 AM | #3 |
Rock Crawler Join Date: May 2013 Location: Uniontown
This is my SCX10.1 Dingo. Admittedly, not much about it is stock but the uppers are 103mm and lowers 109mm. Partly the lengths are odd because of the tucked skid, but also the 10.2 axles have different mounting point geometry. I'm retiring this truck in a few months, but I've switched from all thread and tubing to delrin for custom length link making. The rears on this one are custom. As for your driveline angle woes, adjust your top link lengths, or your shock height or chassis mounting position. Sent from my XT1585 using Tapatalk |
02-09-2017, 02:19 PM | #4 |
I had a set of 300 mm wheel base hot racing links from my SXC10 -1 and was able to use pieces with a few 1mm spacers in the links to get my wheel base I needed. Sent from my iPhone using Tapatalk |
02-09-2017, 04:34 PM | #5 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
This is my scx10ii, shortened to 275 wheelbase for the TRC D90 body. I only modified the rear to avoid any panhard steering complications. I used 5mm stainless steel capillary tube, bought on ebay. Cut to length, tapped the ends M4, screwed in M4 grub screws, traxxas ends, job done. Drive shaft is the shorter parts as supplied in the kit. |
Shorter rear links - Similar Threads | ||||
Shorter links | BLOODBANE | Losi Mini-Rock Crawler | 0 | 10-19-2014 06:05 PM |
Ax-10 shorter front links | shockwave | Axial AX-10 Scorpion | 3 | 06-24-2008 07:43 AM |
anyone running shorter front links than back links? | ccampb04 | Tamiya TLT Crawlers | 12 | 04-18-2005 03:24 PM |
