06-09-2017, 04:21 AM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
| Stock ring and pinion wear |
06-09-2017, 05:16 AM | #2 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Stock ring and pinion wear
I'm seeing something similar on mine. The front gear pair pull each other together under forward load, and so have worn ok. The rear pair push each other apart under forward load, and so the wear pattern is not so good. When new, there was no room for a shim, but now there is a bit of play in both. Looks like I can get a 0.3mm shim in under the pinion, so I'm going to try that. |
06-09-2017, 05:21 AM | #3 | |
| Re: Stock ring and pinion wear Quote:
Thinking we should be able to shim outside the bearing on the pinion shaft and have the driveshaft end keep it from pulling in. Last edited by NitroDarwin; 06-09-2017 at 05:24 AM. | |
06-09-2017, 09:14 AM | #4 |
Pebble Pounder Join Date: Aug 2015 Location: US
Add a spacer on the pinion, when the reas sucks it, it will stop it going in. On the pinion between the center drive shaft and axle.. worked for me, stopped the sucks and push, you want to get the pinion far from the gear rather than pushing it Sent from my Nexus 6P using Tapatalk |
06-09-2017, 10:58 AM | #5 |
| Re: Stock ring and pinion wear |
Stock ring and pinion wear - Similar Threads | ||||
stock ring&pinion ratio | easleycrawler | Axial AX-10 Scorpion | 1 | 02-21-2010 01:33 PM |
Ring and pinion wear | Tonelock | HPI Wheely King | 4 | 07-20-2009 03:30 AM |
