06-23-2017, 10:27 AM | #1 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
| Can you purchase the SCX10.2 transmission?
I want to add a 2 speed to an SCX10.1 and read that it's basically a drop in for the SCX10.1 (not sure if this is correct) and if so, can you buy it like the version 1 locked transmission? Does it by any chance take the steel gears from the version 1 locked gearbox? I imagine I could buy every little bit separately but that would cost a lot. Is the SSD 2 speed a good setup? |
06-23-2017, 12:04 PM | #2 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
| Re: Can you purchase the SCX10.2 transmission?
Yes you can, they are just not in yet. TowerHobbies.com | Axial SCX10 Transmission Set Complete There is also a 2 speed set for it, also not in yet. TowerHobbies.com | Axial Transmission 2-Speed Gear Set SCX10 |
06-23-2017, 03:06 PM | #3 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
Not sure how much of a drop in it would be, the scx10II has a different skid for the(rtr) scx10 trans and kit trans. Also the kit trans had 2 additional support brackets that are not on rtr trans
06-23-2017, 08:17 PM | #4 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
You would need the kit trans skid plate and I think it would bolt right in. May have to drill some extra holes in the frame for the added mounts. The kit trans uses different gears than the .1 trans. But they are all metal gears Sent from my iPhone using Tapatalk |
06-24-2017, 02:44 AM | #5 |
RCC Addict Join Date: Oct 2014 Location: UK
It will be a lot easier to just use this: 2 Speed Transmission Kit for Wraith |
06-24-2017, 11:36 AM | #6 |
Rock Stacker Join Date: Dec 2016 Location: Norway
SSD, can you please make a machined aluminium transmission case for the SCX10-ii? Ideally it would be best if sold separately from the transfer case, motor plate and spur gear cover.
06-25-2017, 07:46 PM | #7 |
Pebble Pounder Join Date: Feb 2017 Location: US
I'd suggest using the RC4WD AX2 2 speed transmission. I believe It's got a wider spread between the low range and high range Sent from my LG-H830 using Tapatalk |
06-26-2017, 03:11 AM | #8 | |
| Re: Can you purchase the SCX10.2 transmission? Quote:
BTW I designed both the SSD 2 speed and the AX2. The SSD 2 speed is an improved version and fits the stock gear cover. | |
06-29-2017, 03:26 AM | #9 |
Just thought I'll let everyone know that I picked up the SSD wraith/SCX10 tranny. It's on the slow boat ATM but I'll report back. Looks fantastic and I basically have everything to set it up already. It was extremely affordable for a near complete aluminium cased, metal geared 2 speed! |
Can you purchase the SCX10.2 transmission? - Similar Threads | ||||
Help with purchase? Axial scx10 | goldduck077 | Axial SCX-10 | 10 | 10-16-2014 11:39 AM |
Going to purchase SCX10 Kit, need advice. | Mules50 | Axial SCX-10 | 14 | 02-01-2014 09:16 PM |
New to crawling... Wraith or SCX10...Which to purchase??? | albassett | Newbie General | 22 | 01-12-2012 03:24 PM |
