08-09-2017, 10:55 PM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Swartz Creek ~ MI
| Suspension Link Set's for SCX10 II
There are a lot of Suspension Link Set's out there now for SCX10 II Don't know if Any One set is better then the other and vary in price from $59. to $79. dollars a set. Some have no rod ends some come with plastic rod ends and some have metal rod ends. After checking them all out on the interweb. I decided to go with the: Integy ~ Stainless Steel Linkage Set w/ Alloy Rod Ends One of the higher priced set's at $79. I like the Alloy Red rod ends I think they will go good with all my Red STRC Part's that I have on my truck now. |
08-09-2017, 11:56 PM | #2 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
| Re: Suspension Link Set's for SCX10 II
I have those metal end on my build but they are a bit narrow and I had install a specter and washers to make up the gap. Just an FYI...
08-10-2017, 03:12 AM | #3 |
RCC Addict Join Date: Oct 2014 Location: UK
Aluminum rod ends are generally not a good idea. The balls are usually sloppy and the rod ends usually bend easily. It's much cheaper and easier to replace a cheap plastic rod end. Plastic rod ends will flex a bit and the balls are tight. |
08-10-2017, 05:05 AM | #4 |
Thanks, kaaina & SSD ~ For the INFO I haven't ordered a set yet so I am going to look in to the SSD Ones once agine. That dose make sense about the flex ability of the plastic rod ends. It dose pay to post before you buy, Lessen learned. ~ Thanks agine !!! |
08-10-2017, 06:04 AM | #5 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
I went one of the more expensive routes but couldn't be happier. I am using the Samix Ti high clearance link set with RPM rod ends. The RPMs are super beefy! I use the RC4WD SS Axial width balls, come with ends but the plastic is brittle and only m3 thread so I just toss them. The RPMs hold them super snug and I haven't gotten any play out of any of my three trucks I have set up with these. Sent from my SM-N910P using Tapatalk |
08-11-2017, 10:52 AM | #6 |
Rock Crawler Join Date: Mar 2016 Location: HB
SSD has a nice set of stainless links for the deuce that you should check out
08-12-2017, 09:56 AM | #7 | |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| Re: Suspension Link Set's for SCX10 II Quote:
08-15-2017, 01:40 PM | #8 |
whats the deal with the holes in the samix links??
08-15-2017, 01:44 PM | #9 |
probabvly helps screwing in the rod ends by sliding there a counter force tool
08-15-2017, 01:46 PM | #10 |
Definitely makes screwing on the rod ends easier, not a fan of the look but the added clearance is well worth it. Sent from my SM-N910P using Tapatalk |
08-16-2017, 10:19 AM | #11 |
Up-Date: 8-16-2017 After looking at all the link set's out there for the SCX10 II ~ All once more. There All Good ~ STRC / Vanquish / SSD and Others all make vary good link sets. I decided to get: The ones in the pics below that I found on the Bay. Thay look vary heavy duty and comes with a Four Link Option, All the Rod End's and Hardware. |
Suspension Link Set's for SCX10 II - Similar Threads | ||||
SCX10 Front Suspension Link Question | SunnyBeach | Newbie General | 8 | 04-29-2015 04:26 PM |
