01-03-2018, 10:17 AM | #1 |
Newbie Join Date: Dec 2017 Location: Atlanta
| Weight bias Front to Rear
I'm planning on adding weight to my kit SCX10.2 axles. As a general question though, how much more wieght do you guys run on the front axle vs the rear. I'm sure it varies, but there has to be a ballpark range. My current plan would give an give an axle weight (not including shafts, gears, spool, bearings) of roughly 285g for the front and 240g for the rear. None of this is rotating weight BTW. What do you y'all think? Good? Too much? Too much on the front/rear? Too little? |
01-03-2018, 01:03 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Weight bias Front to Rear
Around 60/40 overall would be a good starting point, methinks (check by putting the front wheels on a scale, then the rears, battery installed of course).
01-03-2018, 01:40 PM | #3 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
planing on runing most of the brass uprgrades available for the axles
01-03-2018, 03:05 PM | #4 |
I try for 55-60% of the weight up front. Seems to be a good balance of weight up front for ascending while not leaving the rear too light when coming downhill.
01-03-2018, 07:25 PM | #5 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
I try to do 70 30 split for comp /scale rigs. And the 12.3 wheelbase. It'll climb like a mule. Plus tsls.
01-04-2018, 09:31 AM | #6 |
Thanks for the feedback guys. I ordered a scale from Amazon that should be here today. I'll do some weighing tonight and post an update. My truck has the ESC in a different location, so currently there is only a small forward weight bias.
Weight bias Front to Rear - Similar Threads | ||||
How much weight to add to front bias for better climbing | mobgma | Axial SCX10 II | 4 | 02-21-2017 12:59 PM |
Weight bias and total weight.. | SilmarilS | Team Losi Comp Crawler | 3 | 11-25-2014 01:10 AM |
Front to rear weight bias? What works for you? | crazyorigin | Formula Offroad | 2 | 06-08-2011 06:49 PM |
Front to rear weight bias..... | Pappy | General Crawlers | 8 | 12-09-2010 12:26 AM |
Wheel weight vs. chassis weight ratio OR spung/unsprung bias | solomon7 | Tires and Wheels | 15 | 08-02-2008 06:26 PM |
