Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: SCX10 Body on VS410 Chassis Kit
Old 10-20-2021, 10:25 PM   #1
Default SCX10 Body on VS410 Chassis Kit
My girlfriend has an SCX10.2 with the Proline Ramcharger body. She has spent a lot of time painting the body and adding scale details to make it her own. I want to upgrade her into a Vanquish chassis kit. How well will her body fit the Vanquish chassis with the factory Axial holes? It needs to look acceptable so I think this will be the deciding factor.
2wheeler is offline   Reply With Quote
Old 10-21-2021, 12:01 PM   #2
Default Re: SCX10 Body on VS410 Chassis Kit
Pretty well from what I am told. The chassis kit is designed to directly replace the SCX 10 II kit as an upgrade.
Sent from my moto z4 using Tapatalk
FlatLander72 is offline   Reply With Quote
Old 10-21-2021, 12:35 PM   #3
If you have a 3D printer and can do some basic CAD you can make adapters to move the body posts to where they need to be. I've done this for a few of my projects.
That said I can check the hole spacing later tonight. I do remember the rear body post arent just a straight post they're offset, but in theory you could reuse the old body posts.
HumboldtEF is offline   Reply With Quote
Old 10-21-2021, 01:25 PM   #4
The factory holes on my TRX4 Bronco body line up perfectly with both my 10ii and VS410, so I can't see you having any problems with that.
I'm not 100% sure on the rear holes as I cut my bronco into a cab-only, but I'm willing to bet they line up too.
ScaleLifeNewbie is offline   Reply With Quote
Old 10-21-2021, 06:52 PM   #5
Thank you for the positive response. I did search a little and most people use a new body when they swap over to the new chassis so I wasn't sure.
HumboldtEF If you could remember to measure tonight that would 100% confirm our thoughts. Thank you
Old 10-21-2021, 07:07 PM   #6
For the VS410 the spacing (left side to right side) for both the front and back is 2 7/8", the spacing for the front to the rear posts is just over 10 5/8" (+ 1/32") and thats factoring in using a straight body post not an offset one.
The width matches my SCX10.2 but the length does not... but my setup isnt a stock body and I've moved the rear shock towers. Check yours, my guess is it will match up better than mine.
Old 10-21-2021, 10:00 PM   #7
Thank you so much for your time!
It fits as you would expect for a direct replacement chassis.
Left to right is exact and front to back I measure 1/8" difference but that's variable/minor to what it could have been.
Ordering now! Thanks guys.
SCX10 Body on VS410 Chassis Kit - Similar Threads
Second crawler, but first Axial-based: UMG10 kit or VS410 kit? Something else? jessedacri General Scale Talk 18 05-06-2019 02:02 PM
