03-26-2020, 11:03 AM | #1 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Topher Builds a SCX10.3
Sometimes there’s a silver lining to being stuck inside, and when one of the most anticipated RC releases coincides with being proverbially grounded, things don’t seem all that bad. So I got to wrenching and wanted to share some updates with you all here. At this point I’ve completed the axles, shocks, transmission, and links. I’m working on getting the chassis going and shooting to have a roller before the end of the day, maybe some paint too. For this one I’m running the TGH overdrive portal gears, which run a pretty aggressive OD at over 30%. I also robbed the vitavon brass portal covers out of the Capra and will be using them here. The build so far has gone smooth, nothing too out of the ordinary of note, the updates Rich provided were definitely helpful. The quality of the materials is great, same good stuff as the Capra. I didn’t take any pictures of the motor mount loose, but I liked it. Metal, beefy, and the position markings were easy to read and use. The little nuts for the motor mount didn’t give me any trouble to install but would be easy to overlook, these are part AX1040 and go on before the lower plate attaches to the transmission. Rich suggests a dab of CA glue to hold them in place if you have issues (I did not). For anyone looking for the optional gear set for straight axles, it’s available on the axial site already Axial Racing - Input Metal Gears 27T, 20T & 34T: SCX10III Should have some more to share later today. |
03-26-2020, 12:14 PM | #2 |
| Re: Topher Builds a SCX10.3
Sweet! I hope to get started soon too! Man, I haven't even put up my SSD TK build up yet!
03-26-2020, 12:29 PM | #3 |
Newbie Join Date: Mar 2019 Location: Thousand Oaks
Started building mine last night. One thing I noticed is that the gear mesh in the front axle seems good only if you apply tension to the end of the shaft where the driveline would connect. Curious if anyone else noticed this?
03-26-2020, 01:27 PM | #4 | |
Only a little bit of progress so far but wanted to share this pic of the skid, as you can see it’s a bit different since the link mounts bolt on to the skid. There are also 3 positions on each mount. I’m starting with what’s recommended in the directions. Quote:
So many tiny trucks right now! Post it up eh? | |
03-26-2020, 04:13 PM | #5 | |
| Re: Topher Builds a SCX10.3 Quote:
That tranny and transfer setup looks hawt! Very nice that Axial made the rear upper link mounts bolt to the skid and with multiple link mount holes! Yes, shim the pinion gear shaft on the outside to keep it from sucking into the ring gear and binding. | |
03-26-2020, 04:50 PM | #6 |
We got a slider! I forgot I won’t have paint and tires till tomorrow, so for tonight I’ll just button up the rest of the chassis details and get the boys prepped. Running the springs backwards from the manual, as I wanted the more firm springs in the rear. |
03-26-2020, 04:57 PM | #7 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Awesome! Just got word and mine should be on it's way to me tomorrow. |
03-26-2020, 07:36 PM | #8 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Sweet build
03-26-2020, 10:28 PM | #9 | |
Interesting you say that about the springs, the TRX4 Sport kit is the same way. Rear springs are much softer. Not sure if that has to do with the weight balance on the chassis or what. | |
03-26-2020, 11:02 PM | #10 |
I wanna be Dave Join Date: Sep 2019 Location: US
Looks good. I see you used the Vitavon brass portal covers from the Capra...smart move. I have some questions I'm hoping you can answer. I'm trying to figure out some things related to possible wheelbase lengths, but, so far, have been unable to get any useful info. As I understand it (I'm looking at the manual, since I don't have an SCX10.3), the rear rails are "sandwiched" between the front rails & skid. Based on the manual, the rear rails appear to have 10 holes, with the screws being set 4 holes apart (ie. holes 1 & 5, or 3 & 7, etc). For the 12.3" (313mm) wheelbase, are the screws inserted through holes 1 & 5, exactly as shown in the manual? If so, I'm guessing this means the wheelbase can be shortened, but not lengthened? On the other hand, if the 12.3" wheelbase isn't created by inserting the screws through holes 1 & 5, be which holes actually create the 12.3" wheelbase? Lastly, from center-to-center, how far apart are each of the 10 holes on the rear rails. Essentially, I'm still considering that 329mm wheelbase project I mentioned a couple months ago, and the SCX10.3 is a new possibility for that project...I just need to determine how viable this new possibility might be. Depending on the distance between each of those 10 holes, that will help me make that detention. The SCX10.3 could either become my #1 possibility...or, it could be eliminated completely. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
03-27-2020, 12:24 AM | #11 | ||
Got a little bit more work done and it’s just about ready for paint and finishing touches. Waiting on the paint in the mail, as well as the tires which I’ll hopefully have sometime tomorrow afternoon. Here are a couple pics with the body mocked up and the chassis buttoned up. I like how the sliders capture the body and add nice scale detail. The motor cover is nice and installs easily and sturdily. The grill being precut out is something to be thankful for, that would have been tough to cut clean by hand. I’m excited to get this one painted and dressed up. Quote:
03-27-2020, 01:27 AM | #12 |
Damn, you work fast. I don't know how you find the time. Great job though!
03-27-2020, 02:04 AM | #13 |
Ok...created separate thread. No worries.
03-27-2020, 07:26 AM | #14 |
Sorry Panther, that’s all quite a bit off topic from this specific build here and not really looking to dive into the possibilities of your build in this thread. Please start your own thread for that. Thanks Soze! It wasn’t too bad a of a build overall, everything went together smoothly. I have a 2nd one here I was going to do a straight axle swap on, but after mocking it up on this first build I’m going to hold off. Even so, it’s been a challenge to not start opening and building things in the 2nd kit. |
03-27-2020, 08:32 AM | #15 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
Looking good, man! Can't wait to get started on mine next week. I guess you didn't have an e-clip leftover after the tranny was together? Wanna tease on the paint color, or is it going to be a surprise? |
03-27-2020, 08:42 AM | #16 |
I didn’t have any E clips left over. IIRC I used 3 big ones and then the 2 small ones on the dig and shift levers. What size did you have left over and are using both the 2 speed and dig? Paint is going to be simple on this one and I’m thinking orange, but also have some gun metal coming too. |
03-27-2020, 08:49 AM | #17 | |
I put my orange BOM up against the gun metal part on my TRX-4...I can see that! | |
03-27-2020, 09:14 AM | #18 | |
I’m not sure if it will be all orange (and black) or all gun metal (and black) or a bit of each, we’ll see how it goes when I start taping. | |
03-27-2020, 11:15 AM | #19 |
Sweet build! I like the colors you are hinting at! Being on lock down and stuck inside really is quite nice since we have R/C as a hobby. I don't mind it a bit! Subscribed! |
03-27-2020, 11:33 AM | #20 |
Oh Mr Topher moderator extraordinaire Sir......can I ask a favor? Could you please take a look at Tamiya's palette and see which red may most closely match the red accents on the Rubicon and Jeep badge stickers from the kit? I want to order paint but I can't get a good read on colors from the box art. https://www.tamiya.com/english/produ...y/kit86001.htm Thanks a bunch in advance! |
Topher Builds a SCX10.3 - Similar Threads | ||||
topher builds a TRX10.2 | Topher Builds | Traxxas TRX-4 | 60 | 01-05-2021 07:59 PM |
topher builds a Capra | Topher Builds | Axial Capra | 100 | 03-16-2020 08:03 AM |
