Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 III
Thread: SSD RC SCX10 III Parts
Old 08-25-2020, 01:37 PM   #1
SSD
Default SSD RC SCX10 III Parts
We now have a few parts for the SCX10 III available:
Brass diff cover
HD Brass Diff Cover for SCX10 III
Brass knuckles
Brass Knuckles for SCX10 III / Capra
Overdrive steel portal gears
Overdrive Portal Gears for SCX10 III / Capra
Steel portal gears
Steel Portal Gears for SCX10 III / Capra
Brass portal covers
Brass Portal Cover for SCX10 III / Capra
Hex that allow SSD aluminum wheels to clear the portals
Aluminum 6mm Hex Set for SCX10 III / Capra
A full list of compatible SSD parts: PARTS FOR SCX10 III
More are in the works....
SSD is offline   Reply With Quote
Old 08-26-2020, 10:15 AM   #2
Default Re: SSD RC SCX10 III Parts
WOW!! Sexy stuff, well done!
Lou
TK421 is offline   Reply With Quote
Old 08-26-2020, 10:30 AM   #3
Gold Star Baby!
Topher Builds's Avatar
Brass knuckle and portal cover combo is killer!
Any axle housings in the works by chance?
Topher Builds is offline   Reply With Quote
Old 08-28-2020, 06:04 AM   #4
Always been a big fan of SSD products, all my rigs have a good dose of the parts. I've got the diff covers on the way, very nice! Looking at the overdrive gear set, but I'm on the fence. 25% is pretty aggressive.
Sent from my moto z4 using Tapatalk
hezzdown is offline   Reply With Quote
Old 08-28-2020, 08:09 AM   #5
Slow is the new Fast
smog's Avatar
100%
...and the finish on these pieces
smog is offline   Reply With Quote
Old 08-28-2020, 01:14 PM   #6
Sharp stuff!
bigcanoe is offline   Reply With Quote
Old 09-14-2020, 10:07 PM   #7
I noticed when I put the overdrive gear in the front axle. The transmission did not like it. There was grinding noises under a load. Anyone else run into thus problem
2manytickets is offline   Reply With Quote
Old 10-24-2020, 04:26 PM   #8
im running the overdrive ring and pinion in the scx10 iii Gladiator and have not had that problem.
Crush is offline   Reply With Quote
Old 10-24-2020, 04:30 PM   #9
Gold Star Baby!
Try the stock pinion and OD ring gear, might get a little better mesh.
Old 05-11-2021, 10:15 PM   #10
Where are the 10.3 straight axle compatible knuckles, c-hubs, and rear weights?
89redranger is offline   Reply With Quote
Old 05-12-2021, 05:38 AM   #11
What he said ^
Lou
Old 05-13-2021, 08:01 PM   #12
I would try the SCX II section. I'm sure someone will correct me if I'm wrong, but I believe the only difference between the scxII and scxIII straight axles is the non-centered pumpkin, otherwise everything else should work.
PARTS FOR SCX10 II
FordSpeed is offline   Reply With Quote
Old 05-13-2021, 08:50 PM   #13
A few others have already tried, the 10.2 knuckles don’t line up...
Lou
Old 05-13-2021, 08:52 PM   #14
PARTS FOR SCX10 II
The outer stub shafts on the 10.3 universals are longer by about 1mm. Which makes knuckles incompatible.
Sent from my SM-S111DL using Tapatalk
Old 05-13-2021, 09:17 PM   #15
Didn't know that. Thanks guys!
SSD RC SCX10 III Parts - Similar Threads
Jato the SCX10 Take III JatoTheRipper Axial SCX10 III 125 05-05-2020 01:10 PM
SCX10 III Parts compatibility FatalMISTER_Z Axial SCX10 II 1 04-14-2020 10:07 PM
SSD Parts on SCX10 ??? n_d_fox Axial SCX-10 20 03-17-2016 12:07 PM
