Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 III
Thread: RC BEE"S HoneyWagon Axial SCX10 iii JLU Wrangler Build
Old 02-09-2021, 06:41 PM   #21
Default Re: RC BEE"S HoneyWagon Axial SCX10 iii JLU Wrangler Build
Got the shocks finally done and the wiring and Panhard issue and the truck is performing well out there will take a video soon.... BUZZZ........
Honeyman108 is offline   Reply With Quote
Old 02-15-2021, 02:12 PM   #22
Final product other than shocks or body swap most everything is on here!!!
Right now it has the big bore comp shocks but am going to test with the element shocks I had intended to use on this rig and as soon as it warms up paint a new body.....
Its weighing in at 8.4 lbs and I want to trim some weight off.....
Any suggestions??????
Also the panhard bar is a bit of a stumper on this rig it is not the same size as the steering link but can't find a definitive measurement eye to eye on the SCX10 iii Panhard bar??????
But will see after I test her out if this winter storm hurries up and goes..... BUZZZZ....
Old 02-17-2021, 06:00 PM   #23
Buzzz Crawlers.......
This project is finally done and ready for a comprehensive crawl test after this winter storm goes away and then I can see if the Panhard is set properly and if the In The Works RC shocks have too much droop and may change to original idea of element shocks and may remove the brass diff covers the Rig is weighing a little over 8 lbs see pics!!!
I did do a nice 30 min test run 2 weeks back to check anything in the motor or trans and it performed great and sounded good except for the panhard bar and steering and shocks!!
Got the Steering Links situation fixed and the Panhard Bar almost fixed and the shocks im still playing with and I figure im trying to get the shocks mounted too far from the options on the shock tower mount and that's why im not getting the right mix of travel and droop I like which is about 50/50 give or take on the Rig...
Also i need to Shim the Differentials and Driveshafts and Portal Stub Axles but everything else looks and sounds good so far!!!!!
Any suggestions comments ideas??
Please BUZZZZZ........
Old 02-20-2021, 02:27 PM   #24
Forgot to post these pics of the Brass and links..... BUZZZZ......
Old 04-10-2021, 08:32 PM   #25
BUZZZZZ..... Crawlers...... Here is my backyard crawler testing course with some Colorado river rocks very slippery and great for testing my new builds before going out for a real crawl! The rig did great today even though im going back to my Hyrax tires it had great torque and stability.... BUZZZZ......
Old 05-04-2021, 03:40 PM   #26
Nice build! What wheels are those? (the all black ones in the last set of pics)
tdo805 is offline   Reply With Quote
Old 05-04-2021, 08:00 PM   #27
Hey man thanks for the props!!! there are 3 sets of wheels on the thread the Shiny Crome ones are GearHead Trail king aluminum EZ-loc wheels the black ones on the red jeep are also Gearhead in Delrin 12 pack EZ loc wheels and the ones in the video are RCLions aluminum wheels from Amazon... Gearheads are my favorite the ezlocs are real nice and perform well and look good.... BUZZZ......
RC BEE"S HoneyWagon Axial SCX10 iii JLU Wrangler Build - Similar Threads
Soze's SCX10 III Jeep JLU Build soze Axial SCX10 III 29 11-04-2021 06:20 AM
Axial SCX10 III Rubicon JLU Waterfall Trail Run 11/29/20 B-MOW71 Scale Videos! 0 12-06-2020 07:11 AM
Axial SCX10 III Rubicon JLU Trail Run 9/26/2020 B-MOW71 Scale Videos! 0 10-04-2020 08:23 AM
NEW Axial Racing SCX24 2019 Jeep Wrangler JLU CRC RTR - IN STOCK NOW! RPP Hobby RPP Hobby 0 11-25-2019 01:06 PM
