Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 III
Thread: Is anybody making a better panhard bar?
Old 02-28-2021, 07:38 AM   #1
Default Is anybody making a better panhard bar?
I went for a run this morning and snapped the panhard rod right where the threads begin. I know that there isn't much room in there for a larger rod, but does anyone know of anything better being sold out there? I haven't found anything and am not really excited by putting another weak stock part back in.
GA Dawg is offline   Reply With Quote
Old 02-28-2021, 09:58 AM   #2
Default Re: Is anybody making a better panhard bar?
I could have sworn , I have seen them. This guy makes a mount tho https://www.shop.com.mm/products/met...104226012.html
Maybe this? https://www.shop.com.mm/products/met...104226012.html
https://www.rcmart.com/samix-titaniu...25hls-00101826
https://www.ebay.com/itm/Samix-SCX10...kAAOSwc9hfkLGP
REDdawn6 is offline   Reply With Quote
Old 02-28-2021, 11:17 AM   #3
The mount is fine. It's the actual bar that broke.
Old 04-04-2021, 09:58 AM   #4
Have you found a solution for this. I have done the very same thing today ?
drzjohn is offline   Reply With Quote
Old 04-04-2021, 10:00 AM   #5
No. I actually replaced it with a stock part last night.
Old 06-21-2021, 03:52 AM   #6
Has anyone found a solution for this ? I snapped another panard bar yesterday!
Old 07-09-2021, 08:00 AM   #7
I would love to know if anyone has found a solution to this. Besides going to the local hobby store and convincing the guys working there to let me rummage through all there Traxis trx links, and servo rods, (which I did, and still couldn’t find one that worked). I’m not sure what to do.
GoliathGladiator is offline   Reply With Quote
Old 07-09-2021, 08:27 AM   #8
Can you post a pic of where it's breaking - is it that the threads are breaking off the rod?
I wonder if you could just make a rod out of something just a little softer that would be less brittle if that's the case - perhaps some aluminum rod? There shouldn't be much pressure on the panhard bar, it's more for keeping things in line.
Maybe something else is out of whack and causing excess force on the rod end?
OutLore is offline   Reply With Quote
Old 09-24-2021, 05:02 AM   #9
I think i might have found the perfect combo of rod ends and bent link.
The rod ends are the offset ones that came with the truck with a slight shave to them.
The link is the drag link that came with the club5 high clearance set.
I also spaced the servo up 1mm.
The servo horn is unknown its just one i had.
Its very very tight but i still get full articulation on both sides, full compression and full steering
kinree is offline   Reply With Quote
Is anybody making a better panhard bar? - Similar Threads
Panhard bar T4rscott Axial SCX-10 3 07-27-2015 10:28 AM
Panhard bar Lemonlegs28 Axial SCX-10 23 07-12-2013 01:59 PM
panhard bar rezz Axial SCX-10 5 03-26-2013 10:04 PM
Panhard bar? Cole82 General Crawlers 18 09-17-2005 09:18 AM
