12-13-2021, 04:08 AM | #1 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
| 3-gear gearbox conversion - gearing question
Morning, I know I have read it somewhere in a thread, but I cannot find this anymore... So really sorry if this is discussed before. At this moment I am building a SCX-10-3 kit, and want to use an Element Stealth gearbox. But i know but this one is geared lower then stock. So I am lookking for some help: - Which pinion / spur is best to avoid a really slow car - What motor is used best? I was thinking a Holmes 27t on 3s for good Torque and decent trailing speed Thanks in advance! |
12-13-2021, 07:43 AM | #2 |
| Re: 3-gear gearbox conversion - gearing question
I was running 56/13 on my 3 gear converted SCXIII with a Castle 3800kv motor on 3S. It had wheel speed in the range I usually prefer but the Castle motor wasn’t as smooth as I liked so I swapped it for a Holmes Puller Pro 2700kv. The 80:1 gear ratio was great for running high RPM brushless motors but not great if you want to run brushed with any sense of wheel speed. If you want to stay brushed, I would recommend pinion/spur gearing in the 3:1 range with a 27T brushed motor.
12-13-2021, 08:57 AM | #3 | |
| Re: 3-gear gearbox conversion - gearing question Quote:
With 3:1 you mean 54 spur and 18 pinion? thanks! | |
12-13-2021, 09:16 AM | #4 | |
On the pinion and spur, yes 54/18 would be a 3:1 ratio. Since you mentioned the Element transmission, I didn’t know if you were going to be running 32P or 48P gears so I didn’t want to give specific tooth counts. That gearing would get the total ratio in the 56:1 range which would allow some decent wheel speed with the RPMs you can get out of a brushed motor on 3S. | |
12-14-2021, 03:32 AM | #5 | |
3-gear gearbox conversion - gearing question - Similar Threads | ||||
New gearbox and gear options | Erik D_lux | EnRoute Berg | 241 | 04-29-2021 12:27 AM |
AX10 gearbox with scx10 2 axles - how's the gearing? | stimpy | Axial SCX10 II | 4 | 01-01-2018 12:03 PM |
Gearbox binding after gear replacement | waqr | Axial Wraith | 10 | 04-09-2017 10:49 PM |
32p Conversion? (56/10 Gearing) | redliner | Axial SCX-10 | 6 | 01-22-2016 08:03 PM |
Axial gearbox gear measures | tarmo120 | Axial SCX-10 | 0 | 08-31-2011 11:43 AM |
