06-18-2011, 10:14 PM | #81 |
| It's alright. Once some body panels are released, I'll have to get another set of skinz from you, then have my clear bra installer apply it. It slid back so now I have about .5mm of body panel exposed on the hood sides. Not a big deal since this thing is going to get hammered Got to get some more pictures and video footage shot with the new look soon. |
06-21-2011, 09:27 PM | #82 |
Well. First real damage has been found. Part of the front bumper, upper supports that tie into the chassis, is broken. Only part that is holding the front bumper on are the two tiny screws at the lower front. I'm guessing it was from one of the many front end impacts/crashes it has suffered. |
06-21-2011, 09:39 PM | #83 | |
06-21-2011, 09:50 PM | #84 | |
Right where the top tubes drop down by the RX tray. Busted right off. Looks like I should be able to drill and tap from the bottom to re-attach them with a couple of 3mm screws. | |
06-26-2011, 08:33 PM | #85 |
Took the Wraith to a Scale comp today. Image thanks to Mitch Got through about 5 gates before twisting the front drive line. It was my bad. I didn't adjust the end points and caused the dogbone to get dislodged and thus causing the wheels to lock up. As the rig hit the rocks, front drive line let go. Then minutes later the front went too! Image thanks to Mitch Last edited by toyofast; 06-26-2011 at 10:27 PM. |
06-27-2011, 03:03 AM | #86 |
Quarry Creeper Join Date: Apr 2010 Location: Wagga Wagga Australia
06-27-2011, 04:29 PM | #87 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
Hey, look what happened to mine over the WCC: Someone put some prototype Super 300's in it... ;) |
06-27-2011, 04:32 PM | #88 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
06-28-2011, 10:21 AM | #89 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Are the drivelines something you could put an internal sleeve in the male part? Little more support there may keep them from twisting/colapsing.
06-28-2011, 10:27 AM | #90 |
06-28-2011, 10:29 AM | #91 |
06-28-2011, 10:35 AM | #92 |
06-28-2011, 10:37 AM | #93 | ||
Pebble Pounder Join Date: May 2011 Location: under a bridge
What would help, is the extra drive shaft parts that are included. Take one of the female slides and cut the end off, fit over the exposed spline, and glue it on. Make sure to leave a little spline exposed!!! It wouldnt be rock solid, but it would help a lot... | ||
06-28-2011, 12:07 PM | #94 |
| I think the plastic just starts to fatigue from the abuse. MIP's would be the best answer.
06-28-2011, 03:35 PM | #95 |
06-28-2011, 04:38 PM | #96 | |
So happy someone else has a camera and uses it in our group! Mitch caught some footage of my rear shaft before it split... Thanks honey! | |
06-28-2011, 05:25 PM | #97 |
Love the wrap Toyo!! At least the failure of these driveshafts is scale. I've seen plenty of twisted splines on 1:1 rigs. |
06-28-2011, 05:27 PM | #98 |
06-28-2011, 05:36 PM | #99 |
06-28-2011, 07:14 PM | #100 |
Just got done smoking the stock motor. I knew it was close to it's end! Good 'ol High Rocks killed it. Last edited by toyofast; 06-28-2011 at 08:26 PM. |
