09-13-2011, 05:26 PM | #41 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
A little carnage after the event, so out came the new parts and new Lube by team3six. This stuff is balck and you can see some of the additives Norm has introduced to it. It goes on nicely.The large bottle that is a squeeze tube makes it so easy to apply. A little bit is all you need to coat the gears Cant wait to run it again to see/feel/hear the difference. |
09-14-2011, 12:06 AM | #42 |
Newbie Join Date: May 2011 Location: Vancouver, WA
| very nice
Devlin I like. Very well designed. Im just now tearing mine down to buid it up. Thinking of coming up north to one of your guys's comps. |
09-14-2011, 09:28 AM | #43 |
Do it Dan,you know where to find the schedule. It would be great to see you again.
09-14-2011, 01:23 PM | #44 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Maybe I'm missing something here, but from the third pic it looks like you're putting a plastic main gear in the transmission case along with metal idler/top gear?
09-14-2011, 03:36 PM | #45 | |
The LHS didnt have the robinson replacemet gear for the ax10 which fits right in the Wraith. So I contacted rbgerrish at Tammies and he turned me on to the RR gear for the diff on a associated gt2. It is part# rrp2241....fits perfect. Did a little more research and it looks like the diff gear for the gt1 will also work but I havnt tried that gear so take it for what its worth. | |
10-01-2011, 02:55 PM | #46 |
Decided it was time to make some changes to the look of the cage and general profile of the rig. I decided to cut the cage and bend the bars. Nothing new, but I liked the look. I started byt cutting off the parts I didnt want to remain. Then a little trimming to the ends so that when it was bent the angles would work out. Also needed to trim the gussets off at the bend so they would flow properly. A little sanding with the dremal to clean up the cuts and some liquid nail super adhesive and this is the end result. Time will tell if the liquid nails adhesive is the right product. Then I thought it would look good with the cross bars also bent down to the main frame. |
10-01-2011, 02:56 PM | #47 |
I was also lucky enough to get ahold of RCBros new window nets. Installed I think these nets add yet another dimension to the profile of the rig. They fit really good and are very easy to install. If you have painted your cage they will also act as a rub rail and protect the paint. Thanks William, I am really happy with the look of these nets. |
10-01-2011, 10:41 PM | #48 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
pretty slick rig! i love the seats! norm's somekinda crafty dude.. |
10-02-2011, 10:51 AM | #49 |
Decided to try something different with the nets.Mounted them on the inside of the tubes,I like the look. |
10-02-2011, 12:06 PM | #50 |
Nets on the inside looks way better. Did you get a chance to drop those new lockers in yet? |
10-02-2011, 02:19 PM | #51 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Good idea on the inside, I'll see what I can do..
10-02-2011, 03:30 PM | #52 | |
I like the fact you can mount them either way, A little dremel work to them and it totally changes the look. Rock racer or madmax,you choose. | |
04-11-2012, 10:58 PM | #53 |
| Re: Hotwheels |
04-11-2012, 11:51 PM | #54 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
| Re: Hotwheels
Yeah I agree 100% that the inside looks better for those nets. Wasn't really digging them before, good idea |
04-12-2012, 09:38 AM | #55 |
| Re: Hotwheels |
04-12-2012, 10:21 AM | #56 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Hotwheels
I am a Hot Wheels collector and I really like the skins on that Wraith!! I guess that is the Ultimate Treasure Hunt....maybe a Super Secret TH...lol. |
04-12-2012, 10:24 AM | #57 |
| Re: Hotwheels
I wonder whose voice that is in the vid Those won't work for me, I need 120 degrees of steering. |
04-12-2012, 01:31 PM | #58 | |
| Re: Hotwheels Quote:
I think you mean 120* of articulation | |
