07-12-2011, 01:00 PM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: San Jose
| MIP and the Wraith
Guys - any word on when we might see Wraith specific parts from MIP? namely drive shafts? is anyone using any of the existing parts on thier Wraith now? thanks guys paul |
07-12-2011, 01:09 PM | #2 |
RCC Addict Join Date: May 2010 Location: The heart of the south
I think Harley is using the standard AX10 MIPs (Non Dig).
07-12-2011, 01:46 PM | #3 |
Newbie Join Date: Jun 2011 Location: Houston, TX (Tomball)
07-12-2011, 03:13 PM | #4 |
Their current shafts work fine. AX10 non-dig are an easy bolt-on if you grab some 4mm pin style set screws.
07-12-2011, 08:23 PM | #5 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
Just installed mine and they worked out great AX-10 non dig |
07-12-2011, 10:46 PM | #6 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
x5, even without the 4mm pins they hold just fine.Line the set screw up with the hole in the pinon and tighten it down.Hasnt come loose yet.
07-12-2011, 10:54 PM | #7 |
07-13-2011, 04:25 AM | #8 |
Pebble Pounder Join Date: Dec 2007 Location: CA
07-13-2011, 04:44 AM | #9 | |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
Well I'm not Harley but....I'm using e-maxx drive shaft pins on my MIP's they work good. They're a little long but once ya seat them just take a dremel and grind off a few threads on head and a little on the other side where it pops thru and your good to go! | |
07-13-2011, 06:00 AM | #10 |
Rock Crawler Join Date: Mar 2006 Location: Up North
| So a 4mm set screw right??? What length will i need? M4X? MM |
07-13-2011, 08:11 AM | #11 |
07-13-2011, 08:13 AM | #12 |
07-13-2011, 08:52 AM | #13 |
07-13-2011, 08:55 AM | #14 |
| Go download the manual from Axial's site. You will be able to answer a lot of your own questions.
07-13-2011, 09:06 AM | #15 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
07-13-2011, 09:12 AM | #16 |
07-13-2011, 09:14 AM | #17 | |
| Quote: Isnt this called a set screw? | |
07-13-2011, 09:15 AM | #18 |
07-13-2011, 09:30 AM | #19 | |
with a 4mm pin-style set screw. Last edited by jeepster73; 07-13-2011 at 09:55 AM. | |
07-13-2011, 07:36 PM | #20 |
