09-21-2011, 02:11 PM | #41 |
Rock Crawler Join Date: Nov 2009 Location: bolivar mo
wraith hybrid. I have ax10's under mine. SC4x 7.5 with MMP on 3s! 14/54 32p. 8lbs flat with battery. Ive crawled one comp and took second and fine tuned it now. I run mine no CHEAT and smart sense activated. Just seemed smoother. Heres some vids. The crawling vid I was videoing and driving so its smoother than it seems. Just wanted to show you all how capable this combo is. Skid, thanks for the start of this. Best upgrade I did all year. Illl post crawling vid when it gets uploaded. http://youtu.be/RPQwPQWvvaQ http://youtu.be/uT20h0ZfAmc Last edited by Mighty1; 09-21-2011 at 05:52 PM. |
09-22-2011, 05:44 PM | #42 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Well, 11 tooth pinion came loose. Tightened back down and the gear mesh binds. Noticed the pinion split in the tooth valley inline with the set screw. |
09-22-2011, 05:46 PM | #43 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Thats sucks on a couple levels...for you, and me ,cause I was just getting ready to pop a 11 toothin and try it out. Maybe I will just for grins and see what happens to mine. |
09-22-2011, 06:23 PM | #44 |
I probably got 20 packs through it. 12t is still going strong in another scaler with the pro4. May have been a fluke of defect? Hard to say for sure. Another $10 either way. Was an AE pinion if it matters.
09-22-2011, 08:16 PM | #45 |
I wanna be Dave Join Date: Dec 2008 Location: ?
09-22-2011, 08:26 PM | #46 |
09-22-2011, 09:28 PM | #47 |
Im totally happy with my sc4x but if the pro4 is smoother,well maybe ill sell mine and get that one. Seriously the things are way to fast,,,,,, I love it!
09-23-2011, 10:31 AM | #48 |
Pebble Pounder Join Date: Mar 2008 Location: El Dorado Hills, Ca
Guys Axial is sending me a Wraith to play with as well so I will be able to help with the setups a bit here. The Pro 4 has more torque than the SC4x but won't rev as much as the Sc4x. Think of it like a 2 stroke vs. a 4 stroke. The 2 pole setup is like a 2 stroke dirt bike, you must spin it up to make it work really well. The Pro 4 has gobs of torque but lacks the top end revability. If you need more speed from the Pro 4 leave the timing low and simply gear it up.
09-23-2011, 11:17 AM | #49 | |
As I see it, it a small trade with the scx4 vs pro4's. Pro4's are a drop in with no modifying to make fit. I had to grind a link mounts and move the trans forward to bit to clear the sc4x, but the sc4x has more rpm range. Both outstanding over powered motors. | |
09-23-2011, 11:28 AM | #50 |
Skid, I don't really need to go 100 mile an hour so I Would trade my sc4x for your pro 4 |
09-23-2011, 11:38 AM | #51 |
Guys I have been running a Tekin 13.5 with great results. Has anyone ever try a 13.5 to compare? |
09-23-2011, 11:51 AM | #52 |
| All I have is a older novak 13.5. Scared to send 16.8 volts to it, but might try 3s. 17.5 runs good but a bit down on top end and torque. Hard to brag about 100 hp when you rode in 200 hp
09-23-2011, 05:37 PM | #53 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I have a Pro4 in mine right now. Awesome motor. 11/54 gearing and on 3s it's probably half again faster than with the stock motor, plus it crawls amazingly well! Randy P, I've read in a short course forum that you don't recommend running the Pro4 with the RS pro. Will the RS pro be fine in a class 3 scaler that isn't being run 1/2 to full throttle all the time? I really want to ditch my MMP and put my RS pro in. |
09-23-2011, 05:57 PM | #54 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Tim, what don't you like about the MMP in your rig? I'm curious 'cause that's what I was planning on using.
09-23-2011, 06:09 PM | #55 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
Hey everyone, brand new to this site. I know this thread is for the wraith( got one and love it) but my question is geared towards the Tekin Pro4 you have been discussing... I have a Losi Night Crawler thats been totally redone with full framerails (TVP is gone) and am building as a TTC rig. Obviously the Losi worm axles suck for wheelspeed. I've played with various brushless setups ( 21.5, 17.5, 13.5, Velineon and an outrunner) and cant seem to find the happy medium between "crawlability" and wheelspeed. A standard 550 shortcourse setup was too long. Do you think this new Pro4 motor with a MMP on 4s may be the answer? FDR is near 80:1 Thanks!
09-23-2011, 06:48 PM | #56 | ||
09-23-2011, 06:57 PM | #57 | |
09-23-2011, 07:10 PM | #58 | |
09-23-2011, 09:34 PM | #59 |
| I've never seen anyone from tekin say it was ok. A few repots of sc4x motors running on them. But tekin always recomended the rx8. Which has some differences. Bigger, up to 6s, no boost and only dual drive mode with a sensored motor.
09-23-2011, 10:40 PM | #60 |
| Yeah, I know they aren't recommended but I'm figuring in a scale truck where you aren't racing around a track at partial to full throttle for 15 minutes, it might be OK. Just want someone from Tekin to "hint" that it's alright.The RX8 is just too big, and I already spent $195 on an RS Pro.
