05-18-2012, 10:19 PM | #41 |
Pebble Pounder Join Date: Nov 2008 Location: "The Grove"
| Re: Moony's Build
Thanks for the feedback, I read your thread a billion times and enjoy the pics. Great job!! Hopefully more to come?
05-23-2012, 07:09 PM | #42 |
Pebble Pounder Join Date: Sep 2010 Location: West Linn
| Re: Moony's Build
Got my 5995TG servo put in the wraith today, and it seems like its running really hot. The servo makes alot of noise just sitting immobile, so im thinking I need to look into the BEC upgrade. Im running the Torquemaster ESC Waterproof version, so what BEC should I be running? It seems like it robbed power from my motor so I need to get this fixed. http://www.servocity.com/html/hs-5995tg_servo.html |
05-23-2012, 07:10 PM | #43 |
| Re: Moony's Build
Castle creations bec, is what I use to use. My buddy uses it as well. Funny though, I run a Savox 1256 and don't use a bec..
05-23-2012, 07:14 PM | #44 |
| Re: Moony's Build
Does it matter what power is sent to it? EDIT: Nevermind i found the answer. Thank you LHS :thumbsup: Last edited by MoonyJohn; 05-23-2012 at 07:27 PM. |
05-30-2012, 09:41 PM | #45 |
| Re: Moony's Build
Some updated pictures of the recent state of the wraith. So far since, I have installed the 5995TG servo from hitec, I lengthened the wheelbase a tad, now im running 91mm links up front with a spacer (around 94mm), and 106mm in the rear. Flexes nicer and the added wheelbass helps lower it a tad. Also put a chevy emblem, rifle and my tow strap in the rear. Rifle ready Mmm, servo power Chevy! And for kicks Memorial weekend support with the american flags in the back Last edited by MoonyJohn; 05-30-2012 at 09:43 PM. |
06-04-2012, 09:35 PM | #46 |
| Re: Moony's Build
For those in the PDX area, the island is partially open. So nice to go there instead of high rocks all the time! Already busted a rear driveshaft, probably time for an aftermarket one. Also will be starting a new wraith build for the gf, she loved it |
06-05-2012, 06:53 PM | #47 |
Newbie Join Date: Feb 2012 Location: Jackson, New Jersey
| Re: Moony's Build
Just read your build. Really enjoyed it john. |
06-05-2012, 09:18 PM | #48 |
| Re: Moony's Build |
06-06-2012, 08:37 PM | #49 |
| Re: Moony's Build |
06-19-2012, 10:16 PM | #50 |
| Re: Moony's Build
Went out for a test run at our local island spot and found a few rocks |
06-23-2012, 04:14 PM | #51 |
| Re: Moony's Build
Bought a 5000 30c 2 cell venom lipo battery yesterday, along with a 23t motor and a waterproof xl5 esc (since my torquemaster died on me!!).. Everything was running smooth until now the esc is blinking green, not fast but its blinking like its not binded. Any suggestions? I was using it maybe 2 hours ago and went to go run it again and it wouldnt move. The steering did work though. It was working really well too! Perfect amount of power and the right amount of wheelspin for my taste Heres some pictures before it stopped on me |
08-11-2012, 01:48 PM | #52 |
| Re: Moony's Build
Switched things up, got a new frame and swapped everything over. Using the stock ripsaws cause they actually bite pretty well! Only thing that sucks about them is that they are light, I want to seperate them someday and get some weight in those with some new wheels! Heres some updated pictures! Axles been seeing some usage Washin off Lots of pictures, just for you guys and gals ;) |
08-11-2012, 02:11 PM | #53 |
Newbie Join Date: Mar 2012 Location: Portland
| Re: Moony's Build
Great pictures. I really like the way you changed up the lights over time. I noticed you switched from a frame mounted to an axle mounted steering servo at one point. Is there an advantage to this?
08-11-2012, 11:07 PM | #54 |
| Re: Moony's Build Thankyou sir. In the process of switching things over i didnt do the links or the panhard mount. I was in a hurry to get it put together so i skipped it. Doesmt seem to be affected much, though i just crawl and dont run it at high speeds so that might be a factor. For me, it works fine without |
09-06-2012, 08:45 PM | #55 |
| Re: Moony's Build
New shoes, used actually.. 2.2 mickey thompsons on stock black 8 holes. Mounted them up reversed, cant tell if it would make a huge difference or not but I decided to do it since Ive seen others do it before. Also got a castle ESC, castle BEC and the rig runs great with the 5995tg servo. No more crazy sounds coming from the servo anymore haha. Heres some shots from today. Debating whether or not to chop the cage up or not. I miss the buggy look from the other wraith chassis I had. |
09-06-2012, 11:17 PM | #56 |
Rock Stacker Join Date: Aug 2011 Location: Calexico
| Re: Moony's Build
How did your rovers work a dont distiguish the color (compund) you choose but for the looks I think there the pink...If so how do they work?? cause a think they look better than the original rovers but people say there to much sticky
09-07-2012, 01:05 PM | #57 |
| Re: Moony's Build
Too much sticky? Nah, they did pretty good. They were almost too soft, burned motors up too quickly.
09-09-2012, 06:33 PM | #58 |
| Re: Moony's Build
Added some camo on the roof, and made myself a windshield. Also did some minor cage work thats in the later pictures. |
