Thread: KoH style Wraith
Old 01-20-2012, 11:10 AM   #41
Default Re: KoH style Wraith
Wow, nice lights...all of them! Like your narrow width with those wheels and 0.225" hubs! Did the bent links eliminate the rub at full steering? How bad was the rub? Assuming it was just on the lower links...
Old 01-20-2012, 06:45 PM   #42
Thx on the lights...was on CAD until 12:30AM again last night...more cool stuff is coming!
The hub situation is actually a real pisser...
- .225" hubs with universals and stock links rub bad!
- .225" hubs with universals and bent links rub even worse!
- .350" hubs with bend links and universals rub bad!
Apparently the only solution is .475" hubs! Just what I wanted to do is spend another $30 and have another set of hubs laying around idle. Be warned...!
Mad4Rnr is offline   Reply With Quote
Old 01-21-2012, 02:28 PM   #43
That Roof light, did come out pretty cool, I like the rock lights you put in too. Wraith is looking good
prusik333 is offline   Reply With Quote
Old 01-21-2012, 11:59 PM   #44
Thx for the info....wider Wraith is NOT what I want! Did you try turning the lower links 90 degrees...I've seen them run two different ways with the way the bends line up. Pics?
Old 01-22-2012, 01:26 AM   #45
DISTURBIN' tha PEACE's Avatar
Wow your lighting is amazing. Daddy like!
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 01-22-2012, 12:25 PM   #46
Thx bud!
I tried turning the lower front links by 90 deg but then I get some binding in the suspension and they still rub a bit at full lock. I'm planning on .475"s up front and keeping the .350"s in the rear....
Thanks!
Old 01-22-2012, 05:55 PM   #47
idk whats different with your wraith and mine, but I'm running the same wheels on .225 hubs and don't have issues with my links..
I still have the "bumpstops" on the back of my knuckles. So I would assume that is why I dont hit the links with my tires. I'm also running the .700 slw v2 wheels. Not the 1in slw v2's.
jthellfire911 is offline   Reply With Quote
Old 01-22-2012, 07:13 PM   #48
.7's should definitely rub less than 1's. Do you run Axial universals? What tires you have?
Old 01-22-2012, 07:56 PM   #49
Yes Im running the axial universals and I am running the tsl boggers. Look at my build thread and see.
Even with the 1in ones I dont see why they would rub.
Old 01-22-2012, 08:48 PM   #50
Looking sweet Eric,nicely done.
J-FAB NOR-CAL is offline   Reply With Quote
Old 01-22-2012, 08:57 PM   #51
www.team3sixrc.com
now that's some brightness Eric
team3six is offline   Reply With Quote
Old 02-12-2012, 03:11 PM   #52
Nice truck! What volts do the 2" rock lights use?
rc's suck is offline   Reply With Quote
Old 02-12-2012, 03:23 PM   #53
Sick. All you need now is some lights.
I am here: http://maps.google.com/maps?ll=38.946813,-104.771288
Soulo747 is offline   Reply With Quote
Old 02-12-2012, 03:35 PM   #54
12v max. 3s lipo is perfect.
Old 02-12-2012, 03:36 PM   #55
Thx! Should I install some more lights?...lol
Old 02-12-2012, 04:12 PM   #56
lights are sick ill be hitting you up soon for a roof light bar soon...as for the rock lights any other color available????
rockin86runner is offline   Reply With Quote
Old 03-08-2012, 01:28 PM   #57
toy4crawlin's Avatar
Very cool
starting relative same build
thanks for sharing
ear mark.
toy4crawlin is offline   Reply With Quote
Old 03-08-2012, 02:47 PM   #58
couldent tell if you had to remove a front link with the cms and panhard?
big daddy smokes is offline   Reply With Quote
Old 03-08-2012, 04:57 PM   #59
Yep
Old 03-08-2012, 08:13 PM   #60
couldn't you adjust you end point adjustment on the radio so the tires don't hit the links? had to on mine with 600 hubs and the SV2 1inch.
hatefulboy is offline   Reply With Quote
