![]() | #1 |
Newbie Join Date: Nov 2011 Location: Middle Of No Where
I'm trying to pop the little silver swival ball thing into the link end with no luck yet. Any tips on getting these things in they seem pretty snug. I'm using the ones that came with the links and I've got the ends on the links already just can't seem to get the balls in. |
![]() | #2 |
Use a set of needle nose pliers. Place the ball on the end and then grab both sides with the pliers (pliers parallel to the rod end), then clamp down, twist and push it in there.
![]() | #3 |
i set the ball on my bench with the hole up and pop the rod end on by pressing down on it.
![]() | #4 |
Newbie Join Date: Oct 2010 Location: Murrieta
I had a custom machined aluminum block made that was a perfect fit for the rod end. Then use our 25 ton press at work with custom adapters to press it in.
Need info on how to install rear steer on my LNR | blacktoothgrin | General Crawlers | 7 | 05-03-2011 06:13 PM |
Banebot motor install info | pc1 | Redcat Crawlers | 4 | 02-24-2011 04:21 PM |
Ax10 scorpion RTC High clearance link install? | konad | Newbie General | 6 | 09-13-2010 07:29 PM |
Castle Link Install Problem | Knarly Nerd | Electronics | 2 | 06-06-2010 08:51 PM |
