12-18-2011, 07:39 PM | #1 |
Newbie Join Date: Nov 2011 Location: Gibsons B.C
| To grease or not to grease?...... that is my question
Just wondering if you guys are greasing anything ?...... like spurr and pinion or bearings or u-joints or shafts or......
12-18-2011, 07:44 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
| Re: To grease or not to grease?...... that is my question
Grease the ring and pinion in the axles, and the gears in the trans. I run everything else dry. I may put a few drops of light machine oil on the u joints.
02-06-2012, 07:56 PM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
What kind of grease would be best for the diffs and trans? Anything special?
02-06-2012, 10:22 PM | #4 |
| Re: To grease or not to grease?...... that is my question |
02-06-2012, 10:37 PM | #5 |
Would white lithium grease be okay or is it too thin of a grease? I have some stuff called 105. Lubriplate.
02-06-2012, 10:50 PM | #6 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Marine grease...water proof, can't get it off my fingers...sticks to my gears, inexpensive, you can't ask for anything more |
02-07-2012, 12:18 AM | #7 |
02-07-2012, 11:17 AM | #8 |
| Re: To grease or not to grease?...... that is my question Okay so I found some grease we had in our garage. Old but it should work fine, it is by Lubriplate also. It is called Boat Trailer wheel bearing grease. It is yellowish white and waterproof. Can't hurt to try this for free..lol. Amazing what one finds while looking through the junk in the garage!!
02-07-2012, 04:27 PM | #9 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
Just watch some grease isn't plastic friendly and will weaken the plastic over time. Whatever you use just make sure it is plastic safe. A lot of marine grease is plastic friendly. I use a dry lubricant for bicycles called white lightening in U's and spur/pinion. It doesn't attract of hold dirty and grim stinks like hell though.
02-07-2012, 04:55 PM | #10 | |
| Re: To grease or not to grease?...... that is my question Quote:
Cool I have White Lightning stuff too. I will use on other parts but I wanted something for the differentials so I am using the Lubriplate Marine wheel bearing stuff, the diffs are mostly metal parts which is nice. I didn't put too much in there anyway. My build is slowly coming along. Step 4 I think..lol. Good tip on the White Lightning, I am glad I got tons of that stuff...hehehe. | |
02-08-2012, 06:05 AM | #11 |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
Check out this article: Bulletproof the Axial Wraith Drivetrain - RC TRUCK STOP : RC TRUCK STOP It has some input on grease from the guys at Axial. |
To grease or not to grease?...... that is my question - Similar Threads | ||||
Grease(lube) Question | RednekCrawler | Newbie General | 6 | 12-18-2011 02:43 PM |
dielectric grease question.... | discgolferlee | Electronics | 12 | 01-26-2011 02:29 PM |
7980 Grease question | Darrell262 | Electronics | 0 | 11-02-2010 07:51 PM |
grease or not to grease that's the question? | philgoods9 | Axial AX-10 Scorpion | 2 | 04-28-2010 07:52 PM |
