01-02-2012, 06:10 PM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: atlanta
| Missing parts from sealed Wraith kit
Hi, Im missing the Input shafts 5x29mm,part #ax30408,e-clips and pins from Bag A.Could I use the Input shafts from my AX10 and longer set screw?Can order from E*** or try to get Axial if they would send me some.Also was missing 8 3mm thin nylon lock nuts.May have been in same parts bag.Thanks,Skip
01-02-2012, 07:09 PM | #2 |
| Re: Missing parts from sealed Wraith kit
I found that many parts weren't in the correct bags when I built my kit. I hate to say this, but you might find it if you open all the bags. It's what i had to do. Eventually I actually had hardware left over... |
01-02-2012, 07:55 PM | #3 |
All other parts are built,Had two packs of hardware in the bag where the shafts should be.Most companies weigh bag parts so the extra hardware may be way it was "QC/OK".May use the AX10's,only 1mm shorter so I can atleast get it mocked and wired.Calling Axial tomorrow.thanks
01-02-2012, 08:21 PM | #4 |
Rock Stacker Join Date: Apr 2011 Location: Helper, UTAH
Just bought a sealed RTR wraith and it is missing both of tge lower front shock cups??? The little piece that helps keep the spring on!
01-02-2012, 08:31 PM | #5 |
Email Axial or call, they will help you out. |
Missing parts from sealed Wraith kit - Similar Threads | ||||
New Wraith Kit, what am I missing? | HurricaneSpike | Axial Wraith | 12 | 11-29-2011 09:03 PM |
Axial Wraith - Missing Parts? | CEEJAY5 | Axial Wraith | 11 | 07-08-2011 09:09 PM |
