Thread: br xl or sv2?
Old 01-04-2012, 11:59 AM   #1
Default br xl or sv2?
Hi there,
I was trying to order the Holmes brxl with a torque master but the ESC is out of stock. But I do like having the option to switch to brushless if I want with the Castle SV2. So what will I be missing out on if I go with a Castle vs Holmes Esc? Or what is a great Esc for my Wraith that takes both brushed and brushless? Will I loose much low speed control with diff esc's?
Thanks!
Stan3535 is offline   Reply With Quote
Old 01-04-2012, 02:25 PM   #2
Sometimes, I make things.
crazyorigin's Avatar
Default Re: br xl or sv2?
The BRXL is a touch better with low speed control and is a better choice if you want to have a specific brushed ESC, I love my BRXL, but the SV2 is also a good ESC, I have the older Sidewinder and they work well (I don't think there is much of a difference in them). If you want to save some $ and also use brushless if you want go with the SV2, but if you want the best brushed performance go with the BRXL, both are the same size so there is no issues there and fit in the stock ESC cradle if you are using that.
crazyorigin is offline   Reply With Quote
Old 01-04-2012, 04:04 PM   #3
BRXL can also be waterproofed.
thzero is offline   Reply With Quote
Old 01-04-2012, 04:52 PM   #4
I burned up three SV2's before finally getting the waterproofed BRXL.
Wish I'd saved my money and gotten the good one first.
The Castle MM Pro is also really good and will run both brushed and brushless with up to 6s lipo.
meatmonkey is offline   Reply With Quote
br xl or sv2? - Similar Threads
need help with my cc sv2 esc mini freak Electronics 1 11-26-2011 04:06 PM
cc sidewinder sv2 on 4s? iluvny081 Electronics 15 10-13-2011 01:08 AM
Castle Sv2 shwng1973 Newbie General 1 09-19-2011 09:40 PM
Sv2 bs! Jeepkid Electronics 1 02-17-2011 09:47 PM
Sv2 mudn_1 Electronics 13 02-16-2011 03:59 PM
