Thread: Front Shock Mounts
Old 01-23-2012, 06:55 PM   #1
Default Front Shock Mounts
Since I had the X-Band saw out to finish up a rear cargo tray, I decided to make a couple of front shock mounts just for fun. I have a CKRC lowering kit, but did not really want to cut more holes in the hood and because I am using Proline Slash front shocks which are shorter I don't need it any lower than it already is. But I used the CKRC front plate as a template to make my version of custom mounts. It didn't really do much other than move the upper shock mount point forward, a bit higher and slightly more vertical (side to side)
Second pic is with the Proline in the stock location, and third pic is it inthe new forward location. Forth pic is a comparison of stock and the new forward location.
Land Crab is offline   Reply With Quote
Old 01-23-2012, 08:34 PM   #2
Default Re: Front Shock Mounts
The mounts look nice and clean, but I can not for 1 single reason see why you would want to relocate your shocks to be even more strait up. What is the intention here?
NFA Fabrication is offline   Reply With Quote
Old 01-23-2012, 08:46 PM   #3
Because I could I figured since the CKRC mounts have 6 different possible mounting points, all of them higher and 4 of them more forward, I figured why not???
Is there a down side?
Old 01-23-2012, 10:24 PM   #4
4RunnerKid's Avatar
the shocks are more effective that way, with only a slight loss in travel
mounts came out clean, nice work
4RunnerKid is offline   Reply With Quote
Old 01-26-2012, 09:39 PM   #5
Some of you guys running faster motors could probably make good use of this actually, I am just stuck in "Crawler Mode" thinking, which isn't what the Wraith was actually designed for anyway. Looks clean!
Old 01-26-2012, 09:46 PM   #6
does standing the shocks up (more vertical) give more or less crawlability? (is crawlability a word?)
notfastenuff is offline   Reply With Quote
Old 01-26-2012, 10:50 PM   #7
it reduces travel and makes it more stiff(if using the same oil and springs)
Gen3_Teg_88 is offline   Reply With Quote
Old 01-27-2012, 12:09 PM   #8
zjguy721's Avatar
The more they lay down, the more articulation you get and the "softer" the action is given same specs. Standing them up stiffens them up and reduces your articulation.
zjguy721 is offline   Reply With Quote
Front Shock Mounts - Similar Threads
shock mounts krazycrawler888 Redcat Crawlers 1 12-15-2010 09:01 PM
My new shock mounts. 1\4elliptic toy Venom Creeper 22 01-26-2009 01:07 PM
shock mounts? TeamDeweyRacing General Crawlers 0 01-12-2007 12:10 AM
Shock Mounts/ Lower link mounts Maxx4life Traxxas Crawlers 11 07-06-2005 12:36 AM
