12-23-2011, 04:16 PM | #1 |
Newbie Join Date: Jun 2011 Location: Houston, TX (Tomball)
| Drive shaft pins!
call me a noob or what have you but i am having holy matrimony trying to get either drive shaft pin loose from the pinion shaft... I have bent the 1.5mm wrench and honestly, im surprised i haven't stripped either of them out yet! i have been tapping on it lightly with a semi heavy object to "warm it up" and still nothing.... I'm letting the PB blaster set in right now but after being dowb for over a MONTH im ready for these beefy MIP replacments to be in there! coming from the automotive world, i would have already hit it with a "pocket torch" to get the heat in there but i cant see how i could do that in this case without melting something down! thx for any advice gents, -Marcus |
12-23-2011, 04:56 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: Drive shaft pins!
I am also in for any tips RCC peeps may throw out. Im in the same boat after I exposed mine to some salt water at the coast. I got the front out but the rear is frozen and I already broke one high quality allen trying to free it. Ive tried penetrant and heat with no effect. Mine is fine for now until I twist a shaft and it has to come apart.
12-23-2011, 05:08 PM | #3 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
| Re: Drive shaft pins! Quote:
Would a Soldering iron get hot enough to heat the area up. A Dremel Cutof tool to cut up the drive shaft wrked for me. I was gettin ready to install E-Maxx shafts anyway. | |
12-23-2011, 05:11 PM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: Albany
I had to drill one of mine out after I stripped it. It came out pretty easy.
12-23-2011, 08:39 PM | #5 |
Newbie Join Date: Jan 2011 Location: yreka,Crawlifornia
I broke a high end 1.5 hex wrench trying to remove one...wtf?had to grind it out...wut are they useing there to asemble these?
01-27-2012, 03:06 AM | #6 |
Newbie Join Date: May 2008 Location: Everett
I drilled out 3 and used a dremel on the 4th. Naturally, new ones are on backorder. I tried a spare from my mini revo but it was too short. |
01-27-2012, 04:43 AM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
If the metal is seized together then I'm not sure,,, BUT, if its due to factory thread locker just holding on that well, you can heat your Allen wrench very hot and put it in the hole.. Wait a minute for it to transfer the heat to the grub screw pin. that will break the loctite loose. Ive had many in the past that I had to cut with a dremmel, but its not pretty.. Go so hot it melted the rubber sealed bearing sheids. This was on my AX10, they only had a grub. With an entire pin there's more spots to seize. |
01-27-2012, 05:25 AM | #8 |
RCC Addict Join Date: May 2009 Location: Weston
It's most likely a thread locker overload problem. Use your soldering iron to heat it up and break down the thread lock. |
01-27-2012, 07:10 AM | #9 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
Ran into this last nite with a pinion gear set screw, even broke the tip off my Hudy trying to get it out. The hole in the set screw was a little wore out so I was adding side pressure to try to break it loose then snap. Put the tip of my soldering iron on the set screw for a couple of minutes and it came rite out. |
01-27-2012, 08:00 AM | #10 |
Quarry Creeper Join Date: Nov 2011 Location: Vacaville
+1 for the soldering iron. I like to use a small 10 watt with a fine tip to get right in the set screw.
01-27-2012, 08:45 AM | #11 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
I will second the soldering iron idea. Have done that a couple times, when thread locker was used. In my opinion the problem is the coatings the manufacturers are using. I think they react with the thread locker and make thread cement. Give this a read if all else fails. Stripped Hex Screw - Craftsman Screw Extractor |
Drive shaft pins! - Similar Threads | ||||
steel shaft pins | chiatw73 | General Crawlers | 4 | 02-02-2011 09:44 AM |
Comp Crawler Chromoly Pins – Drive shaft, axle, wheel | Erik D_lux | Axles, Trannys, T-case | 29 | 01-31-2011 01:05 PM |
Junfac shaft pins and jb weld | RickM | Axial AX-10 Scorpion | 4 | 10-01-2010 03:29 PM |
**Give away!!** Comp Crawler Chromoly Pins – Drive shaft, axle, wheel | Erik D_lux | Team Losi Comp Crawler | 61 | 07-09-2010 12:22 AM |
night crawler drive pins | samdog | Team Losi Comp Crawler | 5 | 11-18-2009 11:39 AM |
