02-15-2012, 09:23 AM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: USA
| Question for the masters here on Tekin Pro 4 gearing...
I'm using a Tekin Pro 4 with Robinson Racing Xtra Hard 5mm Pinion 14T. Any Masters wanna chime in on what spur gear I should be using? I'm currently using a 32 pitch 56T Spur gear and the gears are not meshing correctly, the pinion and spur teeth seem to jam up and not be the same space apart.. I would greatly appreciate any help! |
02-15-2012, 09:37 AM | #2 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Question for the masters here on Tekin Pro 4 gearing... |
02-15-2012, 09:48 AM | #3 |
Thanks! am i correct to say i have the wrong pitches and should make sure both gears are in the same pitch?
02-15-2012, 12:40 PM | #4 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Sounds like it. Both need to be 32p, for obvious reasons... I use 15/60 with Great results. No desire to change it. Great mix of Both Speed and Crawlability. http://www.rpphobby.com/product_p/asc91166.htm http://www.rpphobby.com/product_p/dtxc9396.htm |
02-15-2012, 03:22 PM | #5 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Sounds to me like you have a MOD1 5mm pinion. They look like a 32 pitch gear, and are very close. More like a 30 Pitch really. Losi short course 4x4 trucks use them. |
02-18-2012, 07:48 PM | #6 | |
Quarry Creeper Join Date: May 2010 Location: rock hill
| Re: Question for the masters here on Tekin Pro 4 gearing... Quote:
02-18-2012, 07:56 PM | #7 |
Mine fit fine. I dont run a spur cover.. Got room for plunty more spur or pinion aswell. Stock motor mount and everything. |
02-18-2012, 08:04 PM | #8 |
No spur cover either. Weird
Question for the masters here on Tekin Pro 4 gearing... - Similar Threads | ||||
tekin pro4 gearing | guidetti_angelo | Axial Wraith | 57 | 03-22-2013 08:38 AM |
pls help me choose. Tekin rs pro or mamba max pro? | painter4x4 | Axial Wraith | 9 | 01-14-2012 09:48 AM |
Tekin rs-pro 17.5 question | Walter95 | Electronics | 5 | 05-08-2011 02:21 PM |
Question for the styrene masters?? | Desert Rc | General Scale Talk | 6 | 05-05-2011 12:15 PM |
LiPo/Hyperion question for the masters | cruciface | Newbie General | 5 | 05-04-2008 01:06 AM |
