03-06-2012, 07:34 PM | #1 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
| NorZepol's Rubi Wraith
Just finished painting and mounting my Dynamic Concepts Rubi body on my Wraith. After installation of some Axial Lights and some headlight lenses from RC4WD. All I need is some parts to put together 2 driveshafts and a light kit, then she'll be up and running |
03-06-2012, 08:06 PM | #2 |
Newbie Join Date: Feb 2012 Location: Surrey
| Re: NorZepol's Rubi Wraith
Nice rig! What rims are those? I like the offset. Did you need adapters of some kind to have them stick out that far? Thanks
03-06-2012, 08:19 PM | #3 |
| Re: NorZepol's Rubi Wraith Thanks They are the Monster EX from Mayhem engineering. They come with some adapters but others are available. The adapters on the rig now are the narrow ones.
03-07-2012, 06:56 AM | #4 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
How well does that body fit? After seeing yours you have got me wanting to buy that body now..
03-07-2012, 07:02 AM | #5 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
looks good man. THese Rubi kits are nice. Dynamic Concepts does a great job with them.
03-07-2012, 08:52 AM | #6 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
Looks killer. Do you have to remove the bumper to remove the hood? Just curious because I have the battery mounted up front, and would be a PITA to remove the bumper every time you change the battery.
03-07-2012, 09:08 AM | #7 |
with the Rubi kit you can trim them out for either opening hood or closed. Its up to you. This one appears to be setup in the closed position. But with a couple cuts, some hinges and posts you can make it open up wide.
03-07-2012, 12:56 PM | #8 |
thanks NorZepol i just ordered the rubi body from rpp hobby. rig looks great man ill post a pic of mine when i get it together wainting on the body now and a set of out of stock bevel gears too... |
03-07-2012, 01:19 PM | #9 |
| Re: NorZepol's Rubi Wraith |
03-07-2012, 01:22 PM | #10 |
| Re: NorZepol's Rubi Wraith yes you would have to remove the bumper. Hoosierdaddy is right on, a very simple mod to make a functioning hood. Dynamic Concepts will even sell you the body with a set of hinges, Dubro airplane versions I believe. |
06-26-2012, 11:24 AM | #11 |
Quarry Creeper Join Date: Jul 2008 Location: Stuck in Missouri for now.
I have a question about the headlight covers that you used. Are they the stock ones from the Wraith kit, or are they the RC4WD ones? Did you have to do anything special to get them to mount in place so nicely? And are the headlight buckets mounted behind them as well, and if so, how did you get the buckets to stay in place? I'm going to be ordering one soon, and since I'm trying to get as much scale appearance as I can out, I want my headlights to look as good as your and to ensure that they work. Thanks in advance. |
06-26-2012, 03:02 PM | #12 | |
| Re: NorZepol's Rubi Wraith Quote:
06-26-2012, 07:25 PM | #13 |
bummer :( i wanted to see working lights on a rubi
06-29-2012, 01:40 PM | #14 |
Quarry Creeper Join Date: Feb 2011 Location: Badger State
| Re: NorZepol's Rubi Wraith Check out Wartrader's tip for adding headlights on the Wraith, using the Rubi body. WarTraders Poision Spider Customs Jeep |
06-29-2012, 02:47 PM | #15 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
Clean and classy!
06-29-2012, 10:30 PM | #16 | |
06-29-2012, 10:32 PM | #17 |
NorZepol's Rubi Wraith - Similar Threads | ||||
Dynamic Concepts Wraith Rubi Buggy Panel Set | Dynamic Concepts | Axial Wraith | 98 | 02-23-2023 05:15 PM |
Hoosiers Rubi-Wraith | Hoosierdady | Axial Wraith | 123 | 09-11-2012 03:56 PM |
