04-03-2012, 12:07 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| What a Wraith Chassis looks like on ax10 axles and 1.9
My 1.9 Scale Beater Comp rig. Wraith Chassis wraith interior pan. My own Aluminum panels Electronics Castle Sidewinder V2 Hi Tec 5985 servo Hi tec 645 DIG servo Homes 35t expert motor. Lipo 3S thunder power 2150 25C 50b. Drivetrain: SCx10 Axles internally weighted. 43 under drive in rear axle MIP drive shafts Wraith tranny with HR dig unit , for now. may upgrade to sx10 trans and vp dig. Hit tec 645 servo 85t spur 48p, may upgrade to 32ptch Tires: testing out- 1.9 Pitbulls VS New compound IroKs Wheels 1.9 Alloy beadlocks foams Nova Soft 7 med. Steering XR10 steering hubs, knuckles and axle shafts Custom panhard Custom chassis mounted steering hit tec 7954 300+ at 6 volts Suspension: 4 link rear with 5/16 Steel tube and 5/16 Delrin uppers 3 link Front with 5/16 steel tube. Losi 4" alloy shocks Scale Sway bars Transmitter, RX Custom DX6i Pistol, run dig and maybe a winch rx ar500 Last edited by toy4crawlin; 04-05-2012 at 10:05 AM. |
04-03-2012, 12:14 PM | #2 |
| Re: What a Wraith Chassis looks like on ax10 axles and 1.9
This was my first attempt to a 3 link. i read a few articals which all made sense. 1. make your pivots points of your Panhard bar relative to your Drag link locations 2. make your panhard bar relative length as drag link ( link from you steering to your knuckle. 3. make your links as parrallel to each other and horizontal as possible. 4. Fit your Panhard bar just in front of your axle Pumkin but behind your Drag link so that the Panhard does not hinder your travel, Clarance I nailed it the first round of the build if you look behind the Drag link you can almost see the Panhard bar I will post other pics to provide a better view of all suspension travel situations. XR10 steering on ax10 Axles Weighted Axles. aprox 1 oz per side of axle. Just over 2 oz total in the rear. |
04-03-2012, 12:20 PM | #3 |
Rear Axle is located so that the chassis hits the ground before it Flops backwards It actually drives wheelies! |
04-03-2012, 06:37 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: missoula
What did you use for steering im building one of these for my daughter they look so cool and i think will work very good i hope!
04-05-2012, 10:08 AM | #5 |
| Re: What a Wraith Chassis looks like on ax10 axles and 1.9 |
12-28-2013, 01:22 PM | #6 |
Newbie Join Date: Oct 2013 Location: st.clair
What length links did you use?
02-03-2014, 11:00 PM | #7 |
Front battery mod has been done Race seats installed DIG system tuned weighted just right at 70/30 @ 8lbs picked up a Spektrum DX3 Cal hood Crawls well, though I think I will go softer foams and try the Pitbull tires |
What a Wraith Chassis looks like on ax10 axles and 1.9 - Similar Threads | ||||
First of its kind,"Top Secret BatMan" hybrid Wraith chassis with AX10 axles | Mighty1 | 2.2 Scale Rigs | 29 | 12-30-2013 11:22 AM |
difference between ax10 and wraith axles | phre0n | Axial Wraith | 7 | 11-20-2011 01:30 PM |
