04-18-2012, 01:40 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: SWE
| your top 5 from this platform.
If you were given 5 choices/upgrades/tuning for improving crawling on your Wraith. What woud that top 5 be? for narrowing it down a bit. This is your wraith setup atm, so 5 up from this platform. Tekin FXR - 45t - 3s lipo- 1500mAh up front - esc,rx back 4ws - all steel/alu knuckle,hubs & steerlinks - weighted tires - 60/40 2x 20kg savöx digital - cvds - hd shafts - beadlocks- modified ripsaws internal modified stockshocks, supersoft springs front, soft rear anti ax twist modified reerright shock. lowered front&back, a bit more lowfront for better 4link pos. stock 20/80 pinion/spur - stock bevel gear set So swaping things, adding or both? what is you thoughts? |
04-18-2012, 03:30 PM | #2 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
| Re: your top 5 from this platform.
tires would be my top priority. I have been running HB Rovers and really like the. Others may chime in on their tire preferences.
04-18-2012, 06:14 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
My top five must do mods..... 1. Move the battery to the front of the truck. 2. VP steering upgrade 3. Tires, I like the Pro-Line swampers 4. Softer springs, I like Losi golds on axial aluminum shocks. 5. Move the tail lights into the body for a more scale look. |
04-18-2012, 09:10 PM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
What do you think needs to be done? Looks like you've done most of the obvious. Fix what needs to be fixed for your driving style. Forget what everyone else is doing just to be doing. Be you.
04-18-2012, 11:57 PM | #5 | |
| Re: your top 5 from this platform. Quote:
thanks, but the idea was to read what ohters think and are doing so after reading up on that, perhaps borrow some ups or even remake them to fit me =) Quote "tires would be my top priority. I have been running HB Rovers and really like the. Others may chime in on their tire preferences. " i kinda like my ripsaws, they are modified to look/perform more as a comp tire. | |
04-19-2012, 01:47 PM | #6 |
HB Rovers white dot compound are great comp crawler tire. The R35 Ripsaws are pretty good all around though. Sounds like you've pretty much got it covered already. Now you can do the personalization touches with some aeshetics mods? |
04-19-2012, 04:46 PM | #7 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
1: VP Steering upgrades. 2: Hitec 7950 Servo for steering. 3: Water Proof Holmes Hobbies BRXL 4: Holmes Hobbies 13T Crawlmaster 5: 32 Pitch Spur and Pinion 56/14 Free/Low $$ mods. 1: Move battery in front of firewall. 2: Build Water Proof RX box Move to where Battery was. 3: Change Shock fluid/Springs lower ride height 1/4". (DON'T waste money on "LOWERING KITS") |
your top 5 from this platform. - Similar Threads | ||||
MOA Platform | TC09mini | General Crawlers | 13 | 10-08-2009 07:39 AM |
What platform should my 1/5 crawler be... | KTM_RACER | Chit Chat | 1 | 10-20-2008 08:16 PM |
What platform | Snaut Rocket | Newbie General | 3 | 02-25-2008 10:12 AM |
