Thread: STRC vs RC4WD upper 4 links
Old 04-23-2012, 06:28 PM   #1
Default STRC vs RC4WD upper 4 links
While trying to spread money out I ordered STRC 4 links off of ebay everyone month or so until I placed an larger order through RC4WD, which included a set of upper 4 links. The RC4WD set with RC4WD rod ends match the stock upper 4 links.
Turns out that it appears that the STRC links either use shorter rod ends? Should I just trim the end of the STRC and use my aluminum RC4WD rod ends or are there short rods ends out there?
lccguy is offline   Reply With Quote
Old 04-24-2012, 09:22 AM   #2
Default Re: STRC vs RC4WD upper 4 links
Does one use the stock end links while the other uses the Revo rod ends? I know the Revo ends are much longer. I'm using those on my link build currently and like them a lot.
ik632 is offline   Reply With Quote
Old 04-24-2012, 09:26 AM   #3
The stock links have the ends incorporated into the links. I'm not familiar with Traxxas stuff but the RC4WD ends are already too long for the STRC links
Old 04-24-2012, 08:24 PM   #4
With my STRC upper and lowers I used the rod ends that came in my Wraith Kit. Fit perfect!!
ZippoMan is offline   Reply With Quote
Old 04-25-2012, 08:56 AM   #5
the revo ends are way more beef. you can just cut them down a little bit and use those. i use either losi or revo for all of my links and steering. they are way stronger than axial rod ends
crawler nut is offline   Reply With Quote
Old 04-25-2012, 09:07 AM   #6
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
You are leaving out a huge amount of important info.
For one, Revo links are not much longer, however Jato ends are roughly 3/4" longer. Both require a 4mm or 8-32 thread. This would require more modification to his links which it does not appear is his intent.
Harley is offline   Reply With Quote
Old 04-25-2012, 09:15 AM   #7
true and that is why i also threw the losi ends in there. i have had way better luck with those ends than axial ends. pack after pack of replacing the axial ends was getting expensive. harley you caught me on the revo part. my bad for not giving more info
Old 04-25-2012, 09:45 AM   #8
Thanks for all the suggestions guys
I just cut the end off, drilled and tapped a new hole and good to go now. I might use a black sharpie to clean up the end a bit, but functionally, it's as good as new
I'm not afraid to mod. Most of my RCs are RC10s, some of which are really mod'd
STRC vs RC4WD upper 4 links - Similar Threads
STRC Links BoardN88 Axial Wraith 21 04-12-2012 09:51 PM
strc steering links pedlhed Newbie General 2 12-31-2011 01:54 AM
STRC Wraith Upper/Lower aluminum links in stock RPP Hobby RPP Hobby 2 09-28-2011 04:12 PM
custom lower and upper links for rc4wd d90? geekfreek95 Axial SCX-10 4 03-21-2011 07:23 PM
axial links vs strc links 30 deg. bend phase10 HPI Wheely King 0 02-01-2008 04:58 PM
