04-29-2012, 12:08 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| hardware to mount VP trans case???
anybody know what size screws are needed to mount the VP trans? Don't know why they wouldn't include the screws since the stock ones don't work. |
04-29-2012, 12:12 PM | #2 |
| Re: hardware to mount VP trans case???
for the screws in the skid? or to screw the trans together? i use 8-10mm for the skid and 25-28mm for the trans depending whats availabe and cut them down to size. i'd tell you exact but dont have a ruler with mm on it.
04-29-2012, 12:39 PM | #3 |
Rock Crawler Join Date: Oct 2011 Location: Lake Worth
Flush mount 8x3mm
04-29-2012, 01:33 PM | #4 | |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
| Re: hardware to mount VP trans case??? Quote:
Is this (linked) what you are talking about? The stock case uses M3x25mm bolts. Why won't the stock bolts work for you? VP Axial AX-10 Alum Trans Housing | |
04-29-2012, 03:24 PM | #5 | |
04-29-2012, 03:29 PM | #6 |
use 2 3x8mm screws and 2 3x10mm screws. if the 10s are to long which i doubt they are cut them down a bit. if you dont already have them it would be a good idea to get a good assortment of 3mm screws to keep in your tool box
04-29-2012, 03:33 PM | #7 |
thanks Crawler
04-29-2012, 03:39 PM | #8 |
or you can just use all 3x8mm screws it wont matter, it will all hold the same
hardware to mount VP trans case??? - Similar Threads | ||||
VP Trans case | Cleaner | Axial AX-10 Scorpion | 11 | 11-26-2010 01:27 PM |
