05-08-2012, 07:24 AM | #1 |
| Vanquish Disc Brake Install
The following post was taken from My build thread. Links: http://www.vanquishproducts.com/dibrfr.html http://www.vanquishproducts.com/dibrreax.html http://www.fasteddybearings.com/axia...h-bearing-kit/ (not required but a good idea to refresh after beating on your truck) Now the VP design is very simple and straight forward, offering maximum adjustment of the caliper location. However there is a problem still, but it's actually the Axial universals (and probably the dog bones). As most of you have probably noticed, there is a TON of end play in the stub shafts. The first thing I did since I was in the area any way replace the bearings. Continuing to use the kit Fast Eddy sent me In order to get rid of the end play I had to use 4 shims of various sizes. Behind the large bearing I used two 0.25mm shims. Behind the front bearing I used one 0.20mm and one .05mm shim. After installing these shims I have nearly zero end play in the stub shaft and the universals still spin freely without bind at full lock. Next I installed the caliper mount on the knuckle. Then slide the rotor on the SLW hub. Install the wheel nut. Now mark the dowel pins to cut them to length. Remove the caliper, cut the pin and reinstall. Last edited by Harley; 05-08-2012 at 12:01 PM. |
05-08-2012, 07:27 AM | #2 |
| Re: Vanquish Disc Brake Install
It is very important to follow the steps above. If you do not the rotor will be constantly rubbing the caliper and you also risk the caliper hitting or rubbing the wheel. You run the risk of damaging the rotor, caliper and mount if you don't do this first thing.
05-08-2012, 07:35 AM | #3 |
| Re: Vanquish Disc Brake Install |
05-08-2012, 07:48 AM | #4 |
05-08-2012, 07:52 AM | #5 |
05-08-2012, 07:56 AM | #6 |
Perfect. Thanks! |
05-08-2012, 11:44 AM | #7 |
Rock Crawler Join Date: Oct 2011 Location: Lake Worth
Where did you get your shims from Also do you have a part number fr these so it's easier just to grab and go Last edited by bagged86; 05-08-2012 at 11:46 AM. Reason: Added on |
05-08-2012, 11:46 AM | #8 |
05-08-2012, 11:50 AM | #9 |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
| Re: Vanquish Disc Brake Install I went to the Fast Eddie site and that part # pops up 3 pages of various kits and parts, but none of which are listed as "Wraith Bearing kit". Is this kit listed under some other name? And are the various sized shims included?
05-08-2012, 11:54 AM | #10 |
| Re: Vanquish Disc Brake Install Hmmm, that was the number on the bag I received. He started a thread here on it, I'll find that. The shims are sold separate.
05-08-2012, 11:58 AM | #11 |
05-08-2012, 12:03 PM | #12 |
Links have been added for the brakes and bearings. Didn't find a shim pack, I'll see what Eddy has.
05-08-2012, 01:52 PM | #13 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
05-08-2012, 04:28 PM | #14 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
uhhg, I totally didn't think of this. My bearings are pretty much shot. Looks like I need to order up some new ones.
05-08-2012, 06:37 PM | #15 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I need two sets of shims for my Wraiths!! It would be cool if someone had a kit for the Wraith. I don't need stacks of shims laying around...lol |
05-08-2012, 06:49 PM | #16 |
| Re: Vanquish Disc Brake Install Outside chance that Fast Eddy could handle that, I really have no idea for sure though. I see he sells shim kits for other trucks.
05-08-2012, 07:50 PM | #17 |
I hope Fast Eddy can make up some kits for the Wraith!! That would be cool or if anyone else could too.
05-08-2012, 08:03 PM | #18 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
Shim kit for the Wraith would be clutch!
05-09-2012, 09:28 AM | #19 |
Quarry Creeper Join Date: Aug 2007 Location: El Dorado Hills Ca
Im working on a shim kit for this. It may take a while but Ill get it done. Here is a link to the bearing set. Axial Wraith Bearing Kit Just an FYI. I have 2 sites that look close to the same. www.FastEddyBearings.com (Bearing Kits) www.TeamFastEddy.com (5th Scale parts) Last edited by FastEddy; 05-09-2012 at 09:30 AM. |
05-09-2012, 12:19 PM | #20 |
OK Shims are ordered in and will be available by late next week. Ill make a kit that will include what you need to do 1 SET of 2 rotors. Is that what you want? |
Vanquish Disc Brake Install - Similar Threads | ||||
Vanquish Wraith Rear Lockouts Review and Install | FastEddy | Axial Wraith | 0 | 10-29-2011 08:46 AM |
Disc brake rotors for my Grand Cherokee | War Pig | General Scale Talk | 14 | 11-28-2009 09:31 AM |
Bike Disc Brake Bleeding? | K_Willis | Chit Chat | 18 | 06-15-2007 06:47 AM |
