06-05-2012, 03:05 PM | #1 |
Newbie Join Date: Jun 2012 Location: las vegas
| New Wraith RTR owner--Front End Question
Hi All, I Just picked up a Shiney new RTR Wraith, and I have a couple of questions about upgrading some front end components. I dont like the flimsy plastic steering linkage, and I was considering getting rid of the dogbones while I'm at it. My question is Should I just by the Axial Aluminum steering links like the Kit comes with, or should I go with another kind? It seems that there are TONS of options, and quite honestly, I'm looking to spend as little as possible (unless that particular part would be just as bad). It seems like anything would be better than the plastic that Axial used for these parts. Also, with regard to the front universals, will the Axial Universals work without changing anything else? Sorry, guys, I'm sure this has been covered time and time again, but the search function gives me so many results, that I've been reading for hours, and I'm still not sure what the best route is. Thanks! Sean |
06-05-2012, 03:12 PM | #2 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
| Re: New Wraith RTR owner--Front End Question
Did you read Harley's Wraith Beginners Guide? Have you read other's build threads? Pics and info of products can be found. Axial AR60 universals are a direct swap. Look up Vanquish Products and Chaotic Crawlers, they make very nice steering and drag links. If you don't want to spend a load of money, replace items as they break. |
06-05-2012, 07:45 PM | #3 |
Newbie Join Date: Mar 2012 Location: Utah
The axial universals have worked great for me so far. I think that is the best route. Any steering links are going to be more sturdy than the plastic ones. I bought the rc4wd links cheap and they have worked awesome as well.
06-05-2012, 09:59 PM | #4 |
Axial Universals are a direct fit and I encourage you to get them. For the steering linkage the Vanquish titanium tie rod is highly recommended. Don't waste your money on their drag link though.. It's not as much of a high stress part and just using a short Axial aluminum link or cobbling together some 8/32" all thread of the right length should be plenty strong enough and will save you some money. |
06-06-2012, 12:49 AM | #5 | |
| Re: New Wraith RTR owner--Front End Question Quote:
Thanks for the advice! That is exactly what I was hoping for: I'll spend money where it makes sense, but I don't want to swap parts just for the sake of swapping parts. BTW, Anyone use this linkage? https://www.ckrccrawlers.com/hr-alum...st-p-4389.html it is super inexpensive, but I don't want to waste the time, if it is flimsy. | |
06-06-2012, 01:04 AM | #6 |
It's not that great because it used the stock plastic rod ends. This is what I got, almost as cheap, but better: http://store.rc4wd.com/Aluminum-Stee...th_p_1959.html |
06-06-2012, 04:55 AM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
I use 4mm all thread.. or Threaded rod as its called here.. ha An I use 1/4 brake line. Pick up some Traxxas Revo rod ends cut the Threaded rod and a bit longer than needed to allow for the bend.. Thread the revo ends on and check length. This will allow you to know the length of the brake line sleeving needed. Cut the brakeline, remove on rod end, slide the brake line over the threaded rod, install the rod end, Add a small bend in the middle of the new rod you just made to allow differential clearance. I always make mine a bit long. then I can test fit after its bent and remove the rod end and trim the threaded rod and brake line a little at a time to get the length just right.. Its Super cheap to do and SUPER strong. I use the same thing to make all my linkages for all my trucks. NEVER broke any yet. |
06-06-2012, 05:03 AM | #8 |
| Not a perfect picture of my steering link.. But it gives you an idea... In this pick I'm testing out Delrin drag link.. It's white 5/16 delrin.. Works fine for short links but is harder to make links with in my opinion.. Also, as soon as you bend it, it stays too flexabile.. No better than stock links.. Sent from my highly abused iPhone using Tapatalk |
06-06-2012, 07:44 AM | #9 |
Rock Stacker Join Date: Mar 2012 Location: Salt Lake City
Here's the one I've been using for about 3 months: Topcad Aluminum Steering Linkage PART: #23003gu Cheap but sturdy... |
06-06-2012, 09:19 AM | #10 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
I'm currently running CKRC's "Suicide Switch" steering, but it seems a bit sloppy to me. I'm in the process of making my own drag link & tie rod using 3/16 steel rod and 1/4" stainless tube for sleeving, along wit Revo rod ends. So far it's cost me about $13 for materials, with the rod ends being about $9. If it's not bomb proof, I don't know what is!
New Wraith RTR owner--Front End Question - Similar Threads | ||||
Saggy front end on new RTR | RCT | Axial SCX-10 | 8 | 02-02-2012 09:15 PM |
new wraith owner | ld markey | Michigan | 12 | 10-31-2011 06:04 PM |
New RTR owner | Eticket | Axial AX-10 Scorpion | 4 | 06-02-2008 08:33 AM |
